Bounty Hunter Posted May 11, 2006 Share Posted May 11, 2006 I need to tigthen the downpipe where it attaches to the exhaust manifold, does the Renix use a donut gasket here? Link to comment Share on other sites More sharing options...
mjeff87 Posted May 11, 2006 Share Posted May 11, 2006 Mine doesn't (although it's a 2.5...it's still Renix :D ). Just 2 studs on the end of the manifold that fit thru a flange collar on the pipe, held by 2 9/16" nuts. The end of the intermediate pipe is flared a bit. Simple but cheezy design IMHO, but it works! Jeff Link to comment Share on other sites More sharing options...
Eagle Posted May 11, 2006 Share Posted May 11, 2006 4.0L uses a donut gasket. Link to comment Share on other sites More sharing options...
Pete M Posted May 11, 2006 Share Posted May 11, 2006 I don't remember a gasket back when I was screwing around with the exhaust on my 88, but maybe it had welded itself to the manifold? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 11, 2006 Share Posted May 11, 2006 Be MIGHTY careful and LOTSA lube, you don't wanna break those puppys off!!! I just did mine last friday!!! Did not break them either!! :) Good luck, CW Link to comment Share on other sites More sharing options...
Stumpy Posted May 12, 2006 Share Posted May 12, 2006 mine has one. i changed it out as it was leaking, but found out it was the manifold... :mad: Link to comment Share on other sites More sharing options...
