mvusse Posted April 30, 2008 Posted April 30, 2008 Just replaced my track bar bracket (old one was bent and had a broken weld), track bar (ball joint was messed up/wore out on the old one) and ps lca. When I got the old one off and held it sideways, both steel bushing fell out... Now my front axle is finally centered like it should be, and hopefully no more death wobble. With the axle over 3/8" from where it was, my steering wheel is almost 1/4 turn past straight when driving straight, but it turns the same amount both directions before the stops. So the question is: what do I adjust to get the steering wheel pointing correctly? I guess the drag link could do it, but then I'd be able to turn sharper one direction than the other, right? So that leaves either the steering wheel itself, or where the shaft hooks up to the steering box, if that even is adjustable. Next up (probably this weekend) is the gas tank.
Chico Posted April 30, 2008 Posted April 30, 2008 Mv, it's adjust the drive link to staighten your steering wheel. There was a really good post w/ pictures earlier. I just can't find it. Maybe someone can post the link.
HOrnbrod Posted April 30, 2008 Posted April 30, 2008 Mv, it's adjust the drive link to staighten your steering wheel. There was a really good post w/ pictures earlier. I just can't find it. Maybe someone can post the link. http://comancheclub.com/forums/viewtopic.php?t=7687&highlight=steering+wheel+center+centre
Chico Posted April 30, 2008 Posted April 30, 2008 Found it http://comancheclub.com/forums/viewtopic.php?t=7687&highlight=steering+wheel
Wildman Posted April 30, 2008 Posted April 30, 2008 Had to dig real deep.......but I found the posts- http://comancheclub.com/forums/viewtopi ... ring+wheel Yes, it's the drag link that center's up the steering wheel And good luck on that pile of parts :D
mvusse Posted April 30, 2008 Author Posted April 30, 2008 That article is about adjusting the drag link. But won't adjusting the drag link affect the stops? Never looked at the steering system closely yet. Are the stops built into the steering box, or are they external? If external, where are they at, and can they be adjusted?
Wildman Posted April 30, 2008 Posted April 30, 2008 That article is about adjusting the drag link. But won't adjusting the drag link affect the stops? Never looked at the steering system closely yet. Are the stops built into the steering box, or are they external? If external, where are they at, and can they be adjusted? They are external, on the front of the axle, about 3-4 inches in from the yoke. if there not froze up, you can adjust the extrema turns. There just a bolt taped into the axle. Adjusting the drag link should not affect the stops.
mvusse Posted April 30, 2008 Author Posted April 30, 2008 All right then. I'll adjust the drag link after work tomorrow Wildman: Thanks for the parts and meeting me halfway. I worked off breakfast with a 20 mile bicycle ride on the greenway trail there, and got burnt to a crisp. Entire head (maybe a hat wouldn't be such a bad idea now that I have no hair anymore) and neck. Average mileage for 215 miles was 21 mpg. Better than I expected. 8)
HOrnbrod Posted April 30, 2008 Posted April 30, 2008 They are external, on the front of the axle, about 3-4 inches in from the yoke. if there not froze up, you can adjust the extrema turns. There just a bolt taped into the axle. Adjusting the drag link should not affect the stops. Adjusting the drag link will not affect the stops, it only centers the steering wheel. But the toe adjustment must be done first to center the tie rod.
Wildman Posted April 30, 2008 Posted April 30, 2008 All right then. I'll adjust the drag link after work tomorrow Wildman: Thanks for the parts and meeting me halfway. I worked off breakfast with a 20 mile bicycle ride on the greenway trail there, and got burnt to a crisp. Entire head (maybe a hat wouldn't be such a bad idea now that I have no hair anymore) and neck. Average mileage for 215 miles was 21 mpg. Better than I expected. 8) :D No Problem :thumbsup: Now you do need to order the hat :brows: And 21mpg......that's good for the automatic, I didn't check my mpg this trip, but now I got to check it, should be about that......I didn't push it on the way back ;)
Eagle Posted April 30, 2008 Posted April 30, 2008 That article is about adjusting the drag link. But won't adjusting the drag link affect the stops? Simple answer -- no. Adjusting the drag link is how you center the steering wheel. It will not affect the stops.
