removing the dash...
hey guys i got some bad news...my lights worked for about 2 days then more stuff shorted and lots of wires melted so...i have a complete wiring harness with the fuse box...what i need to know is how to take the dash apart..is it hard..how many bolts...any special tricks?
thanks...
I'll need your email... I only found two relevent pages, but it gets you threw the first hurdle. I can remember from when I stripped mine that I couldn't find anything after these two pages, but it was no big deal...
Oh, I got my knee in the one pic. It looks odd.
I know the base part of the dash is held to the firewall with 6 or 7 small bolts that you can access after removal of a small trim piece that runs over the defrost vents. The lower dash will have to come off. After you remove the glovebox door, you should be able to access and remove all of the fasteners for the trim that goes around the glovebox and the small cubby hole beneath it. The two bolts that hold the steering column to the dash will have to be removed.
You'll probably have to remove the brake/clutch pedal assembly completely. I can't remember how the HVAC system mounts to the dash and if it is necessary to pull it as well. I believe the last thing would be 2 or three fairly large bolts (M10-12?) that fasten laterally into each A-pillar. Don't forget to disconnect and label any salvageable wiring.
It's not bad, just time consuming.
