How do I remove bumper caps?
No. Since i can't remember any pics of this i will try to explain... Two small bolts per cap, the ones on bottom are very easy, just look under your bumper. The other ones are on top (almost straight above the bottom ones), access to these are another story, especially the passenger side one. :headpop: First thing: remove small mud flaps on each side under and behind bumper; then remove the 'tylenol' pill shaped vacuum cannister (passenger side) for better access (two screws on bottom). You should now be able to reach up with a deep walled socket to remove the nuts; before doing this you need to squeez an open end wrench to back up the bolt heads. They are between the bumper cap and the turn signal lamp housing. After removing the bolts you will need to bend and twist the cap to get it out. You will learn a few more 'words of wisdom' by the time your finished! :mad: Thanx to the engineers who designed this!
trees, rocks, hills..etc. lol sorry couldnt resist..hehe if would had them on mine the other day when a 30" tire standing up was wedged under the corner of my bumper (long story..i need a bigger floor jack. ;) ) lol
