Center Dash Vent....Is there a non-Ghetto way to keep it facing up (or at lest not drooping all the way down). At the JY, I looked at some XJ Dash pieces and it looks like the center section is molded in there and not really (or easily) removable/replaceable.
Cig Lighter... Mine doesn't stay popped it... if I hold it in, it gets hot, but it won't stay in to get hot on it's own and then pop out. a) Is this normal, B) In No, is that a problem with the lighter itself, or the pug?
See I told you these were dumb questions, and I was embarrassed to call them "Tech"...
I'm working on all the little piddly stuff that I can since I know the engine needs to be re-done and I now have a Front Axle Seal Leak (probably when I yanked the shafts when I did the ball joints). After spending a buttload of $$$ on my back yard, I'm pretty much tapped out and can only work on the 'cheap' stuff (like removing my Strips and messing with the interior stuff... :cheers: )
If you take the lighter off (housing) and unscrew the back part you will see two clips that you can push in that holds the lighter in and when it gets hot the metal expands and allows the lighter to pop out. you,,you,,,you,,,,,, smoker........ lol
Actually not a smoker... I just like to burn stuff... hehehehe...
I just want all the parts and pieces to work, even if I'm not going to use them...And Like I said, I'm bored silly and have no Cash!
that's the way the lighter in my friends honda prelude is. you gotta hold it in to get hot. so i decided i was going to try to fix it. well i gotta it to stay in and pop out, and it would literally "pop out" just about making it to the back seat.
Prelude FTMFW!!!!!!!!!!!
