i'm looking around for disconnects for my front sway bar. for those of you with discos, what are you running, and what do you think of them?
i am considering buying used ones, will discos from a YJ or TJ work?
XJ, TJ, and MJ ones should all be fairly interchangeable based on the height (length) needed.
To use a YJ set you'll need a "hoop bracket" to convert the stud type mounting to an eye-ring mount to be used on the MJ.
JKS is the BOMB!!!
cw
X2.....I scored a used set of JKS quicker disconnects (newer version) for $50 ;) and love them.
Jeff
No swaybars on the MJ but I have Teraflex discos on my XJ and have no complaints, they disconnect and reconnect easily. They're basically the same design as JKS only non-adjustable.
