bekkip Posted May 1, 2006 Share Posted May 1, 2006 Hi, I need to buy a 1989 Jeep Comanche PU Repair manual, original factory, not after market. Can someone point me in the right direction for this. Thanks Becky Link to comment Share on other sites More sharing options...
Pete M Posted May 1, 2006 Share Posted May 1, 2006 ebay.com is where I got all of mine. Link to comment Share on other sites More sharing options...
ejndssn Posted May 1, 2006 Share Posted May 1, 2006 its kinda pricey but you may want to try this web site let me us if this works 4 ya :idea: www.thejeep.net/catalog/product_info.ph ... e7558edf26 Link to comment Share on other sites More sharing options...
bekkip Posted May 1, 2006 Author Share Posted May 1, 2006 Thanks for the information. since the mechanic/neighbor is the fellow who wanted me to get an original Manual and the reprint is available I will grit my teeth and go for the pricy one. I may well send for one of the CD's off of Ebay also. Appreciate your help guys. Thanks, Becky :D Link to comment Share on other sites More sharing options...
ROADLESS Posted May 1, 2006 Share Posted May 1, 2006 It appears that the afore mentioned service manual (hard copy) is a compilation of all Jeep models for that year (1989). My question is does this manual contain everything that was in the original hard copy FSM or is it something different? I ask this because even tho I already have a FSM for an 88 XJ/MJ, some of the wire colors are different on my 89 MJ, therefore I too need to get the new, all-in-one, manual. :dunno: Link to comment Share on other sites More sharing options...
bekkip Posted May 1, 2006 Author Share Posted May 1, 2006 Good question, I can only hope that since it says "reprint" of the original that it will be. I will for sure post to the forum good or bad. :roll: Becky Link to comment Share on other sites More sharing options...
Pete M Posted May 1, 2006 Share Posted May 1, 2006 There were some very minor changes between 88 and 89 (mostly wire color differences), but the 89 manuals are Chrysler's version and are still in print. Link to comment Share on other sites More sharing options...
Eagle Posted May 1, 2006 Share Posted May 1, 2006 I ask this because even tho I already have a FSM for an 88 XJ/MJ, ... Are you certain? "The" factory XJ manual for 1988 was the 1986 Cherokee manual, with separate add-on volumes for the transmission; engine; transfer case; electrical system; and I think something else that I can't recall at the moment. It did NOT include the MJ, which was also a 1986 FSM (for the MJ) with supplementary books to cover the equipment that didn't exist or wasn't used in 1986. Bwteen the XJ and the MJ I think I've probably spent about $300 for factory service manuals, and that only covers the transmission and transfer cases I own. I haven't bought a FSM for the 242 transfer case or the AX-15 tranny because they are covered in the '94 XJ/YJ manual, which I have. I just hope there weren't a lot of changes in the intervening 6 years. Link to comment Share on other sites More sharing options...
ROADLESS Posted May 1, 2006 Share Posted May 1, 2006 I ask this because even tho I already have a FSM for an 88 XJ/MJ, ... Are you certain? "The" factory XJ manual for 1988 was the 1986 Cherokee manual, with separate add-on volumes for the transmission; engine; transfer case; electrical system; and I think something else that I can't recall at the moment. It did NOT include the MJ, which was also a 1986 FSM (for the MJ) with supplementary books to cover the equipment that didn't exist or wasn't used in 1986. Bwteen the XJ and the MJ I think I've probably spent about $300 for factory service manuals, and that only covers the transmission and transfer cases I own. I haven't bought a FSM for the 242 transfer case or the AX-15 tranny because they are covered in the '94 XJ/YJ manual, which I have. I just hope there weren't a lot of changes in the intervening 6 years. No. But this is good to know, i @$$umed they were the same! :papers: Link to comment Share on other sites More sharing options...
