Stumpy Posted April 30, 2006 Share Posted April 30, 2006 can i swap gears from a c-clip D35 to a non c-clip D35? the only reason i am wondering is because i just happen to have a set of TJ axles with 4.56's sittin in the garage now... if the gears will swap i could atleast run em til i find a stronger rear axle and get it built. Link to comment Share on other sites More sharing options...
bwatsoncj Posted April 30, 2006 Share Posted April 30, 2006 yes Link to comment Share on other sites More sharing options...
pingpong Posted April 30, 2006 Share Posted April 30, 2006 Yes but the TJ front gears won't work in it. also you need to use the non c-clip spider gears with non c-clip axles. Link to comment Share on other sites More sharing options...
Pete M Posted April 30, 2006 Share Posted April 30, 2006 I think it may be easier to modify the TJ axles to fit the MJ, but pesonally I would just sell 'em. You do realize that swapping gears is no walk in the park, yes? Link to comment Share on other sites More sharing options...
Stumpy Posted May 4, 2006 Author Share Posted May 4, 2006 thanks for the info guys!! which is stronger?...a disco D30 or non-disco? (i like the disco because i plan on "locking it and building a manual disconnect for it.) Link to comment Share on other sites More sharing options...
87manche Posted May 4, 2006 Share Posted May 4, 2006 disco has a stronger UCA mount I believe. It does have the disadvantage of the possibility of bending where the CAD motor is. Of course who's to say that what bent a CAD tube wouldn't bend a non-cad tube. Link to comment Share on other sites More sharing options...
