HO 4.0L Exhaust Manifold
Wait, is there something wrong with your cylinder head? If you just need the exhaust manifold for your non-HO you can get em for less than $100 on EBAy. Of course you can go through the dealer and pay like $600 or if you really want a dealer part PM BLHTAZ. He can get you a better price.
It will physically bolt to the head without issues.
The problem is using the Renix downpipe (it' won't bolt up) so you need to use a HO downpipe as well. The other issue is with the EGR. The HO does not have the port hole for the EGR on it so you either have to ditch your EGR or drill/tap a hole in the HO manifold.
There's absolutely nothing wrong with my cylinder head. By what ya'll were saying, it would not mount up properly so I figured I would need the HO cylinder head. Well if the allignment issue is with the downpipe then there isn't an issue. I'm replacing the entire exhaust system anway. From the exhaust manifold all the way back to the tailpipe. So the downpipe alignment shouldn't be an issue right?
