Hole in throttle body
Mmm..can't right now. Camera is packed up. On my '90 there's a hole in the side of the throttle body about half an inch above the port where the MAP sensor vacuum line plugs in. It's the same size as the MAP sensor port but I can't tell that it goes anywhere.
I wasn't sure. My MAP sensor line was pretty fragile so I replaced the rubber plug and hard plastic line with a rubber hose. The hose I used had just the right outer diameter so I just spit on it (very complicated professional technique) and pushed it in the hole. I gave it a little tug to be sure it isn't coming out, but then I was left with that little double plug thingie. The plug for the top hole has an orifice in it and I thought it might be required, so I cut the double plug in half and stuck the top half back in (no spit required). If it's just for alignment I'll take it back out.
hi,all,my first post.
Might as well be here,I guess.
I just got an "88 mj 4.0,it'll be a resto project.
In searching for a vacuum leak this weekend,
I found the same problem you have,but in that upper hole
was a screw,just flopping around.I assumed that it'd come loose
and wallowed out the hole in the tb,I rtv'd the line into it.
Just happen to work at a Dodge dealer parts dept,so I ordered
a new line .It came in this a.m.,and after reading your post
I looked closely at it.That upper plug is a barbed plug like the lower one,
and has a hole clean through it,so apparently it's just a locator,and not supposed to have a screw in it either,so I'm gonna replace it anyway since I got it,but I think we're both ok.
Retail from your friendly Mopar dealer is $23 for that line,so
vacuum tubing and spit is probably a lovely idea!Might want to rtv it in ,though,since the map sensor is on the firewall,you'll have lots of vibration in that line to the engine.
As I said,new owner,new member,welcome me aboard. :cheers:
I just now was allowed to post,so don't have a signature or avatar
ready yet,I'll do it tonight after work.
