wiring harness questions
Pulled a wiring harness off an 88 4.0/AW4 MJ in the ‘yard today, and have a couple of connectors I need to identify. The MJ had been picked over a bit before I got there and some stuff was missing….I’ve got everything figured out except three connectors to the manifold/TB area, and two connectors under the manifold, in the same loom as the knock sensor.
First, the three on top of the manifold. One is a 4-wire connector:
Blue/yellow tracer
Green/black tracer
Purple/black tracer
Red/yellow tracer
One is a 3-wire flat connector:
Yellow/green tracer
Brown/white tracer
Red/yellow tracer
And one is a 3-wire square connector:
Light gray/black tracer
Red/no tracer
Tan/pink tracer
Image Not Found
The others are below the manifold, in the same loom as the knock sensor:
2-wire connector:
Tan
Brown/white tracer
3-wire connector (is this the O2 sensor connector?):
Orange
Gray
Black
Image Not Found
BTW....here's the whole mess. Took me about 2 hours to pull it all (once I figured out how to get it seperated and pulled thru the front clip :D Got the whole harness, radiator support, fan shroud, ECU, throttle cable and linkage for $50......
Image Not Found
Hey Jeff, if you don't have one already, now is the time to invest in an electrical FSM for your rig. It has pics of all the harnesses with all the connectors labeled. Will be the best $$ you ever spent mate. :cheers:
Thanks guys.....top ones are verified as IAC and TPS (I only need the one becuase of a manual trans). Bottom one still in question is either MAT or coolant temp (thinking it's the MAT, but then I don't know where the coolant temp is now...gonna have to run back down and look at donor vehicle again in the morning to verify)
I do see an FSM in my future, very soon!
"Dis is gonna be fun" :D
Jeff
