Anybody know what some of these mean?
Right Front Spring Group XIV
Left Front Group XV
Rear Spring Group I
Spring Special White Appearance Grp
Kicker/SRT Livin' Loud Audio System (I assume this is just upgraded speakers)
5 Additional Gallons of Gas (I assume this means I have the 23 gallon tank)
Everything else on the list is pretty self explanatory but when they get into the "group" packages where do you look to find out what was included in that group?
I can't help you on the springs and whatnot, but this one I can. It simply means that they put 5 gallons of gas in the tank for you; essentially for test drives at the dealership, and/or so that you can make it to a gas station to fill the tank the rest of the way.
What year MJ and what are the codes associated with those listings? And where did you get the listings?
What you need to be aware of is that Chrysler seems to have recycled some codes that were originally used for XJs and MJs, either by AMC or just after the take-over, in newer vehicles. The result is that you request a build sheet from Chrysler and often you'll get codes for options that didn't even exist when your Jeep was built.
The Kicker/SRT Livin' Loud Audio System is the stereo upgrade on a SRT-4 Neon. The stock stereo was better.
You don't have this option.
The 5 Additional Gallons of Gas is added to the 3 gallons it comes with, in other words it comes new with 8 gallons of gas...
It is a 91 and chrysler didn't send me any codes just a list.
Thank you for contacting the Chrysler Customer Assistance Center
regarding your 1991 Jeep Comanche.
According to our records, your vehicle was equipped from the factory
with the following:
Skid Plate Group
Monotone Paint
75 Amp Alternator
Nickel Metal Hydride Battery
Power Front Disc/Rear Drum Brakes
Straight Back Bench Seat
Carpets - Floor and Cargo Area
All 4-Speed Automatic Transmissions
4-Speed Automatic AW4 Transmission
Lock-Up Torque Converter
Command-Trac Part Time 4WD System
Elec,Shift-on-the-Fly,P/Time T/Case
Dana M30/181MM Front Axle
3.55 Axle Ratio
Dana M35/194MM Rear Axle
4.0L Power Tech I-6 Engine
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Front Left Side Sliding Window
Rear Sliding Window
Left Remote Mirror
Right Remote Control Mirror
Manual Remote Mirrors
Heater w/Instrument Pnl Ventilation
Analog Instrument Cluster
85 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
STRIPE/BADGE/MOLDING
Glove Box Lamp
Halogen Headlamps
Black Front Bumper
Black Front Bumper
Front License Plate Bracket
Black Grille
Black Windshield Moldings
Upper Door Frame Moldings
Belt Moldings
Body Color Drip Trough Molding
Federal Emissions
EVAP Control System
Dark Silver Metallic
Dark Silver Metallic Clear Coat
All Radio Equipped Vehicles
AM/FM Cassette Radio
4 Speakers
Power Rack and Pinion Steering
2-Spoke Soft Feel Steering Wheel
Standard Duty Shock Absorbers
Rear Shock Absorbers
Full Size Spare Tire
Tire Carrier Winch
P215/75R15 OWL All Terrain Tires
Michelin Brand Tires
15X7.0 Styled Steel Wheels
All Steel Wheels
Pickup Box
Build To U S Market Specifications
Rear Spring Group I
GVW/Payload Rating
Left Front Group XV
Our records also show that, your vehicle is involved in the factory
recall campaign listed below:
Recall Campaign # 747 Disc Brake Rotors
with the following:
Skid Plate Group
Spring Special White Appearance Grp NOT
Monotone Paint
Kicker/SRT Livin' Loud Audio System NOT
75 Amp Alternator
3.55 Axle Ratio
Front Left Side Sliding Window NOT
Rear Sliding Window
Left Remote Mirror
Cigar Lighter
Glove Box Lamp
Halogen Headlamps
Black Front Bumper
Black Front Bumper
Black Grille
Belt Moldings
Federal Emissions
EVAP Control System
4 Speakers
Power Rack and Pinion Steering NOT
Tire Carrier Winch
All Steel Wheels
Pickup Box
Rear Spring Group I
GVW/Payload Rating
Left Front Group XV
It's close but not right.
