92comanche4x4 Posted February 29, 2008 Posted February 29, 2008 I know this sounds stupid but what does a bumpstop do?
tjbliley Posted February 29, 2008 Posted February 29, 2008 When the suspension cycles up it stops the movement of the axle before the tire contacts the fender area.
Eagle Posted March 1, 2008 Posted March 1, 2008 When the suspension cycles up it stops the movement of the axle before the tire contacts the fender area. And before the shock absorber piston bottoms out and the shock self-destructs.
TNT Posted March 1, 2008 Posted March 1, 2008 When the suspension cycles up it stops the movement of the axle before the tire contacts the fender area. And before the shock absorber piston bottoms out and the shock self-destructs. It also cushions the impact as the suspension bottoms out. Air bumpstops are the way to go, if you want to go all out. :brows:
92comanche4x4 Posted March 1, 2008 Author Posted March 1, 2008 ok ive seen it so many times i wanted to know what it was
Pete M Posted March 1, 2008 Posted March 1, 2008 Remember the hockey pucks on that axle? Those were cheapie bumpstop "extensions". Extensions is a bad word to use though, as the bumpstop is the thing above them inside the coil. The pucks bring up the platform on which the bumpstop contacts. You may end up needing a couple if you're intent on running 33s.
GosaGT1988 Posted March 3, 2008 Posted March 3, 2008 Trust me, there are no stupid questions here. We're here to help. Heck, even I was wondering what that was when I first got my 1990 MJ.
