MJKally Posted 7 hours ago Posted 7 hours ago I replaced my lower control arms today, while doing so I noticed that the adjustable part on the passenger side is shimmed far enough forward that the bolt is at the end of the slot, and the driver's side has no shims in it at all. And of course as a result, the wheel on the driver's side is about an inch further back than the passenger side. I understand the adjustment in the control arm is to change the caster angle, but why would someone have done it like this? Should I just pull the shims out and set them both back to zero, or if the shims are the same thickness, should I just put one in the other side to even it out? I'm not sure what the correct setting is. The upper control arm on the passenger side looks like it snapped at some point and has been welded back together, I don't know if that has anything to do with it being like this, but that's getting replaced regardless.
pizzaman09 Posted 5 hours ago Posted 5 hours ago I remember reading somewhere that the wheelbase of the MJ is 1/4" different from one side of the truck vs the other from the factory, deliberately. I wonder if someone tried balancing yours out. Just a theory.
Eagle_SX4 Posted 4 hours ago Posted 4 hours ago I also read somewhere that the passenger side is further forward to help with staying on the road. Most paved roads are crowned in the center allowing water to run off. The theory is that with the passenger side being longer it helps counteract the steering pulling you off the road. 1 inch difference seems excessive though.
Eagle_SX4 Posted 4 hours ago Posted 4 hours ago This thread helps with the question some. Apparently it is supposed to be only about 10mm (~3/8) difference side to side.
MJKally Posted 2 hours ago Author Posted 2 hours ago 1 hour ago, Eagle_SX4 said: I also read somewhere that the passenger side is further forward to help with staying on the road. Most paved roads are crowned in the center allowing water to run off. The theory is that with the passenger side being longer it helps counteract the steering pulling you off the road. 1 inch difference seems excessive though. The shims on the passenger side only amount to about half an inch or less, but the measured effect it has is that on the tires in the wheelarch is about an inch difference, as it's pushing the passenger side forward half an inch and the driver's side back half an inch. The offset idea makes some sense, but I'm driving my jeep on the other side of the road here, so it probably won't be helping me much if that's true. I'll give that thread a read, but I think I'll probably end up taking the shims out and setting the caster angle myself.
