AnotherOldJeepGuy Posted 18 hours ago Posted 18 hours ago This morning when I left the house a loud static noise came from behind the dash. It lasted maybe 15s and then stopped. It sounded like noise from a speaker when an amplifier was crapping out, but AFAIK there's no speaker back there. It wasn't RPM related. The cab fan was in the OFF position, but I did turn it up and down through the speed settings, the fan worked in each position (it's a new fan from last summer) and that had no effect on the sound. I do know that sometimes when I first head out my speedometer needle bounces a bit at low speed (under 10 MPH) for a couple minutes which results in a tapping sound in sync with the bounce. But this sound was not that. I turned the radio volume completely down just in case even though I know the speaker is not behind the dash, but that had no effect on the sound. It happened twice separated by no more than a minute and the second time lasted about the same amount of time. There was no third instance of the noise. The truck was running normally. I did later look under the hood just to see if maybe a critter had put something in there that was being whacked by the fan, nothing there. Anyone have any idea what the heck this might have been?
jeff351 Posted 13 hours ago Posted 13 hours ago maybe you ingested some leaves in the blower motor and they eventually got chewed up and spit out?
AnotherOldJeepGuy Posted 10 hours ago Author Posted 10 hours ago 2 hours ago, jeff351 said: maybe you ingested some leaves in the blower motor and they eventually got chewed up and spit out? A reasonable thought. I feel like the sound was different than that but I can't be sure.
PIKE Posted 2 hours ago Posted 2 hours ago I had a 1986 Cherokee that was making a lot of sound behind the dash. It turned out to be the speedometer cable was bad and making the noise.
