I made a post a few years back about wanting to install air conditioning to my truck and never got around to it. The project seems far too complicated and technical for me and not having any cooling in 110 degree weather is the main thing drawing me towards selling the truck and getting a daily driver with an A/C
I live in Northern California around about Sacramento, are there any known shops in say a 500 mile radius that would have the technical know how and experience to install it for me? I’d be willing to drive pretty far and pay a decent bit of money for it but I can’t find anything online that points me in the right direction. Any help would be wonderful I just need some cooling before next summer rolls around.
I would think your best bet is to find a Cherokee same year/engine with A/C and swap everything over.
You could check over at Naxja.org in the Sierra section and see if someone could offer a shop to help.
X2
If you don't have AC at all, your best bet is a donor XJ.  You'll need the AC box under the dash and all the engine bay bits.  Some of the parts can and should be replaced when you're in there.  But starting with a donor XJ is the best bet.
As other have said, find an XJ donor at a junkyard. Grab the HVAC box and everything under the hood. Install on yours. Pull a vacuum yourself and fill it. Buying the tools to do it and getting the parts at a junkyard will be minimal expense. It will be hard to find a shop willing to work on such an old vehicle, and when you do they will charge more than the truck is worth.
