Southpaw Posted 3 hours ago Posted 3 hours ago I have a 1987 Jeep Comanche two wheel drive 4.0 looking for recommendations to put bucket seats to replace the bench seat
Big Dan Posted 3 hours ago Posted 3 hours ago IIRC, seats through 94, from an XJ, will be an easy swap of brackets. 1995 plus are more involved, but doable.
Southpaw Posted 3 hours ago Author Posted 3 hours ago 1 minute ago, Big Dan said: IIRC, seats through 94, from an XJ, will be an easy swap of brackets. 1995 plus are more involved, but doable. Thank you
The86manche Posted 2 hours ago Posted 2 hours ago And there's a gentleman on here that makes seat brackets so you can bolt them right in to the mj. Brandon Scarborough.
Pete M Posted 1 hour ago Posted 1 hour ago keep in mind that only 2dr XJ buckets lean forward. with some minor mods (usually using 1x1 tubing to adapt your floor brackets to the seat base), most any junkyard bucket can be made to work. 2dr cars with generally lean forward. be prepared to fight with unbolting your seat from the floor. I recently had to slice through all the brackets to get a bench out. fortunately Brandon makes replacement brackets
