jodawill Posted June 9 Posted June 9 I need to order a transmission mount. I see Rock Auto lists two different versions from Anchor - 2570 and 2858. They look the same to me. They also don't even have a section for the automatic transmission, so I'm not sure if either of them are correct for my AW4. Does anyone know which transmission mount will work?
pizzaman09 Posted June 9 Posted June 9 I remember running into this when I purchased one at the auto store for my BA10/5. There is a different mount for each the AX-15, BA10/5 and AW4. Unfortunately I'm not sure which is which.
Eagle_SX4 Posted June 9 Posted June 9 I know the Cherokees and Comanches share transmission cross members. So the mount should be the same between them. Rockauto has different mounts listed for the automatic Cherokee. Anchor 2625 should be the correct part number. It is listed under the 89 Comanche automatic transmission, but it is strange rockauto does not list an automatic transmission for 90-92 on the Comanche.
jodawill Posted June 10 Author Posted June 10 5 hours ago, Eagle_SX4 said: I know the Cherokees and Comanches share transmission cross members. So the mount should be the same between them. Rockauto has different mounts listed for the automatic Cherokee. Anchor 2625 should be the correct part number. It is listed under the 89 Comanche automatic transmission, but it is strange rockauto does not list an automatic transmission for 90-92 on the Comanche. Thanks! I ordered that one. We'll see how it goes.
jodawill Posted June 21 Author Posted June 21 I just got it installed. It's completely identical to the original. Thanks!
