Recommended Fuel Pump
I'm looking for the best source to get a new fuel pump for my 88 comanche. I ordered on ebay  but they lost it. Then a friend mentioned something bout a Bosch? Can someone just point me to the right fuel pump replacement
47 minutes ago, fiddlermj said:
Sheeeeesh. I'm gonna prolly need a whole unit considering the one in it is a cherokee
MTS makes and sells new sending units. They use an old style rotary vane pump. The Bosch 69302 is a newer turbine style pump that is much quieter. The ideal solution would be a MTS sending unit and a Bosch pump. I wish MTS made a sending unit that accommodated the new smaller turbine pump.
http://www.mtscompany.com/sendingunits.htm
The part number is JPSU-6. (sending unit only no fuel pump) You have to call them to order.
18 hours ago, AnotherOldJeepGuy said:
I also noticed this apparent alternate from Herko at 1/2 the price.
I bought the regular price one from the same seller about a year ago. I messaged them asking for confirmation that all the pieces needed to swap the shorter turbine pump were present. They responded quickly and sent me pics of everything, which I was impressed with. What came was a NOS genuine Bosch pump in a Carquest box. I think they (and some others) jumped on the big sell-off from Advance/Carquest cutting back operations in 2024-2025.
https://www.ebay.com/itm/176281211480
