eaglescout526 Posted February 27 Share Posted February 27 Ok here’s a fun one. You can not get new boosters for the V8 ZJ. Now what can one do in this situation? I met a couple the other weekend thanks to an AMC friend who said I’d be able to help them. They got a ZJ that was running and currently has no brakes. They were told the booster is bad. I’m going to confirm that this weekend. But upon searching for a booster, they were told you can not get a new booster. I tested that and lo and behold you can’t! Well damn. Anyhow, I call upon CC to help. Would a WJ booster fit? Would that be considered an upgrade to the ZJ? They want this Jeep to be something their granddaughters can drive and I sure as hell want it to be damn safe and reliable. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 27 Share Posted February 27 There appears to be some on rockauto. https://www.rockauto.com/en/catalog/jeep,1995,grand+cherokee,5.2l+v8,1182114,brake+&+wheel+hub,power+brake+booster,1884 Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27 Author Share Posted February 27 37 minutes ago, Eagle_SX4 said: There appears to be some on rockauto. https://www.rockauto.com/en/catalog/jeep,1995,grand+cherokee,5.2l+v8,1182114,brake+&+wheel+hub,power+brake+booster,1884 Well would you look at that. I wonder if 94 is a one year only thing. I’ll get with the owners and see if that’s the route they’d like to go. I can’t imagine there’s much difference. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 27 Share Posted February 27 The 95 ZJ booster looks just like the dual diaphragm booster used in the XJ's in 95. Although it appears to have a shorter actuation rod. The 94 and 95 ZJ's used different boosters and different master cylinders. You could probably change both out and maybe fab up some brake lines and be back on the road. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27 Author Share Posted February 27 10 minutes ago, Eagle_SX4 said: The 95 ZJ booster looks just like the dual diaphragm booster used in the XJ's in 95. Although it appears to have a shorter actuation rod. The 94 and 95 ZJ's used different boosters and different master cylinders. You could probably change both out and maybe fab up some brake lines and be back on the road. Thanks for that! I’m really hoping the booster isn’t bad but the owner said that when he plugs the line to the booster, the engine runs fine but runs rough when unplugged. So I’ve got a bit of digging on this one. Link to comment Share on other sites More sharing options...
89 MJ Posted February 27 Share Posted February 27 I wonder which end of the hose he is plugging. Hopefully its something like a bad hose instead of a bad booster. I know, wishful thinking. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27 Author Share Posted February 27 13 minutes ago, 89 MJ said: I wonder which end of the hose he is plugging. Hopefully its something like a bad hose instead of a bad booster. I know, wishful thinking. I’m inclined to believe his diagnostic method, I will see for myself, this poor ZJ has been beaten on and abused. How ever, when off the pedal is rock hard and it doesn’t even have any brake fluid in the master. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 15 Author Share Posted March 15 Ok If anyone wants an update, heres the update. They got the 95-98 Booster and master. I was able to put them both in. Had to make a slight adjustment to the brake lamp switch bracket and probably will need to adjust the pushrod in the booster but we will see. Sadly this Jeep has a little more to go before being roadworthy but it has brakes and thats the important part. So yes a Later ZJ booster and master will go in to an early ZJ. Link to comment Share on other sites More sharing options...
