WahooSteeler Posted January 16, 2008 Share Posted January 16, 2008 What would be the stock, or most likely, rear diff ratio on an 87 2.5L, 5spd, 2WD w/D35? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 16, 2008 Share Posted January 16, 2008 Probably 4.10 Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 16, 2008 Author Share Posted January 16, 2008 Thanks Adam. Next time, don't take so long to respond, ya hear? :D Ok then, while I'm asking, how about an 88 4.0, AW4, 4x4, D44 w/factory trac-lok and tow pkg "B"? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 16, 2008 Share Posted January 16, 2008 Probably 3.55 That fast enough for ya? :D Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 16, 2008 Share Posted January 16, 2008 And just for reference. 3.07 - used with 4.0L engine / manual transmission 3.55 - used with 4.0L engine / automatic transmission 4.10 - used with 2.5L engine usually (not always, but 90% of the time) 4.56 - rare but can be found on some older (~ 89 ~) models with 2.5L engine and auto transmission Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 16, 2008 Author Share Posted January 16, 2008 Better, still room for improvement though. :laughin: I figured 4.10s on the 2.5, but I was worried I had 3 oh sebens on the D44 cuz at 65-70mph w/30x9'5s she's only turning about 2100-2200 revs. can't imagine w/tow pkg anyone would have put those in there though. 355s i think are perfect for my use. a little help on mpg and still able to tow or haul 3 scoops of mulch! Thanks again........... Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 16, 2008 Share Posted January 16, 2008 3.07 was only found on manual tranny equipped 4.0L's. Now XJ axle's are a totally different story, as their were a few additional axle ratio's found in them... Link to comment Share on other sites More sharing options...
Geonovast Posted January 16, 2008 Share Posted January 16, 2008 And just for reference. 3.07 - used with 4.0L engine / manual transmission 3.55 - used with 4.0L engine / automatic transmission and 2.5 with 4 Speed manual transmission 4.10 - used with 2.5L engine with 5 Speed manual transmission 4.56 - rare but can be found on some older (~ 89 ~) models with 2.5L engine and auto transmission My red truck has a 2.5 / 3.55 because it originally came with a 4 speed. They did that, because with 4.10s and a 5 speed, your final drive is about the same as 3.55 with a 4 speed. Better, still room for improvement though. :laughin: I figured 4.10s on the 2.5, but I was worried I had 3 oh sebens on the D44 cuz at 65-70mph w/30x9'5s she's only turning about 2100-2200 revs. can't imagine w/tow pkg anyone would have put those in there though. 355s i think are perfect for my use. a little help on mpg and still able to tow or haul 3 scoops of mulch! Thanks again........... With 3.07s on stock tires you'd be turning about 2k at 65 mph. So at bigger tires it would be considerably less. Believe me, the 2.5 is a dependable little motor, but I seriously doubt it could turn 30's with 3.07. Mine has a little trouble sometime turning stock comanche tires at 70mph+ in 5th with 3.55. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted January 16, 2008 Share Posted January 16, 2008 My red truck has a 2.5 / 3.55 because it originally came with a 4 speed. They did that, because with 4.10s and a 5 speed, your final drive is about the same as 3.55 with a 4 speed. You may want to double check that. I'm 120% sure that my 2.5L 4 speed has 4.10 gears in it from the factory... Link to comment Share on other sites More sharing options...
Geonovast Posted January 16, 2008 Share Posted January 16, 2008 I'm not saying it's not possible. Anything can be from the factory, the original buyer just has to request it. Link to comment Share on other sites More sharing options...
Pete M Posted January 16, 2008 Share Posted January 16, 2008 My red truck has a 2.5 / 3.55 because it originally came with a 4 speed. They did that, because with 4.10s and a 5 speed, your final drive is about the same as 3.55 with a 4 speed. You may want to double check that. I'm 120% sure that my 2.5L 4 speed has 4.10 gears in it from the factory... Is the 4-speed factory? :D Just kidding. Lots of crazy things happened back in the day. The rule of thumb is that 2.5L + AX4 = 3.55 gears. But the only way to know for sure is to check. Link to comment Share on other sites More sharing options...
Eagle Posted January 16, 2008 Share Posted January 16, 2008 You may want to double check that. I'm 120% sure that my 2.5L 4 speed has 4.10 gears in it from the factory... I have two of them here with 3.55s. 4.10s were for the 5-speed. Link to comment Share on other sites More sharing options...
