Muncher Posted November 21, 2025 Share Posted November 21, 2025 Quick question on the np242 swap. I'm doing a 98 xj ax15 swap and need a t case there's a 98 np242 from a xj with the shift lever peice with it would that shift lever peice swap right into the mj even though its from a newer xj? Link to comment Share on other sites More sharing options...
Muncher Posted November 21, 2025 Author Share Posted November 21, 2025 Also would the driveshaft have the same output shaft as the np242? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted November 21, 2025 Share Posted November 21, 2025 According to the parts diagrams on moparpartsgiant.com. The part number for the shifter housing is the same between the early and late model XJ's. That newer shift gate should bolt right on the shifter in your Comanche. Yes the driveshaft will work just fine. I have a 97 NP242 in my truck and used the original driveshaft. After installing the transfer case double check the length of your driveshaft. I did need to get it shorted by 3/4 of an inch. All the specs I could find said my driveshaft was supposed to be shorter than it was. It may be just mine that was made wrong from the factory. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 22, 2025 Share Posted November 22, 2025 I can confirm the shift gate will fit. I got mine from an 01 XJ and used it in my 90 MJ Link to comment Share on other sites More sharing options...
