Chris86 Posted November 7, 2025 Share Posted November 7, 2025 I found a motor for my jeep Comanche 86 tbi 2.5 but the motor i found is in a 95 jeep wrangler 2.5 fuel rail injector and when I try and research it and it says it possible ive got to change the ecu is this correct everything else looks about right and change the harness under the hood Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 7, 2025 Share Posted November 7, 2025 So are you wanting to convert from Renix to HO? Link to comment Share on other sites More sharing options...
Chris86 Posted November 9, 2025 Author Share Posted November 9, 2025 Yes they said all I would have to do was change the outside harness fuel pump and motor brackets and sensors Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 9, 2025 Share Posted November 9, 2025 I don’t hear about many converting from TBI to HO so this will be neat. I recommend looking at 4.0 Renix to HO swaps since it should be the same just minus 2 cylinders. Link to comment Share on other sites More sharing options...
Chris86 Posted November 10, 2025 Author Share Posted November 10, 2025 But if I go to the 4.0 what all would I have to swap over i know the motor and tranny and transfer case as well i believe and possibly the rear end whats your thoughts see if have found all kinds of 4.0 I can't find the right 2.5 Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 10, 2025 Share Posted November 10, 2025 You’ll need everything from the donor Jeep to swap the drive train. Trans will not bolt up from 2.5 to 4.0. However if your just trying to do a block swap, any 2.5L should bolt in. But going HO is less steps than dropping in a 4.0. Oh and yours being an 86 there’s a 50/50 chance the firewall will be ready for the 4.0. And you’ll also have to swap the front end to get the 4.0 radiator in there. Yeah you’re better off keeping the 2.5. Link to comment Share on other sites More sharing options...
Chris86 Posted November 12, 2025 Author Share Posted November 12, 2025 Yeah I believe i will keep the oh 2.5 and just swap out the harness thats alot easier lol and also another quick question the metal vacuum lines that run into the throttle body can those be taken out and replaced with standard size vacuum hoses i mean the proper sizes or do they have to be metal Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 12, 2025 Share Posted November 12, 2025 You can replace those with any size vac line you want. Doesn’t have to be metal but might last longer if they are. Link to comment Share on other sites More sharing options...
Chris86 Posted November 12, 2025 Author Share Posted November 12, 2025 Ok thank you and where can I find the right fuel pump for my truck everyone says no more than 15 psi but when you order the pump it shows 90 psi and on some they just offer a inline pump 4 to 6 psi got me all confused Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 12, 2025 Share Posted November 12, 2025 I think 90 PSI is just the highest it can produce and could be a pump used in other vehicles. The pressure regulator will take care of the pressure made by the pump. 4-6 psi is low for the TBI. Like you’ll struggle to go anywhere low. Course I didn’t think finding a pump these days was such a challenge. Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted November 12, 2025 Share Posted November 12, 2025 5 hours ago, Chris86 said: Ok thank you and where can I find the right fuel pump for my truck everyone says no more than 15 psi but when you order the pump it shows 90 psi and on some they just offer a inline pump 4 to 6 psi got me all confused Buy the coresponding year/model fuel pump for the motor you are putting in and swap it onto your sending unit Link to comment Share on other sites More sharing options...
Chris86 Posted January 2 Author Share Posted January 2 Ok guys ive finally got it all switched over where can I find a free engine wiring harness for my 86 jeep Comanche 2.5 tbi and find a free engine wiring diagram for the 95 jeep wrangler 2.5 mpfi its not been a bad swap just time consuming switching a couple mounts the hard and fun part is fixing hit me now with the wiring ive done alit of reading and about it I just trying to find some free diegrams any help will be appreciated i will post pics after I do the wiring Link to comment Share on other sites More sharing options...
