Chris86
Chris86's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Does anyone know if this motor amd front end would be worth anything I'm posting pics I know its out of 60 model jeep
  2. Jomj87 I could use some help on the wiring I'm going from a 86 jeep Comanche 2.5 tbi to a 95 jeep wrangler 2.5 mpfi I had to swap some mounts around ive got the motor in and the new fuel pump and lines i only have the engine harness did you happen to take any pictures of the wiring you or diagrams anything you could offer would be great thanks
  3. Ok guys ive finally got it all switched over where can I find a free engine wiring harness for my 86 jeep Comanche 2.5 tbi and find a free engine wiring diagram for the 95 jeep wrangler 2.5 mpfi its not been a bad swap just time consuming switching a couple mounts the hard and fun part is fixing hit me now with the wiring ive done alit of reading and about it I just trying to find some free diegrams any help will be appreciated i will post pics after I do the wiring
  4. If you still need it give me a holler i swapped my 86 tbi to a 95 jeep wrangler 2.5 mpfi tuff challenge but I succeed and I actually have 2
  5. I have a 86 jeep Comanche 2.5 tbi truck 4x4 4 speed manual
  6. Was the swap hard ive got a complete motor and outside harness and ecu i been wanting to make the change for the whole system hut seen how much trouble it is how much trouble was it to switch the fuel system over
  7. Ok thank you and where can I find the right fuel pump for my truck everyone says no more than 15 psi but when you order the pump it shows 90 psi and on some they just offer a inline pump 4 to 6 psi got me all confused
  8. Where can I find the right fuel pump and injector for my 86 jeep Comanche 2.5 tbi single injector and fuel pump is in the tank
  9. Yeah I believe i will keep the oh 2.5 and just swap out the harness thats alot easier lol and also another quick question the metal vacuum lines that run into the throttle body can those be taken out and replaced with standard size vacuum hoses i mean the proper sizes or do they have to be metal
  10. But if I go to the 4.0 what all would I have to swap over i know the motor and tranny and transfer case as well i believe and possibly the rear end whats your thoughts see if have found all kinds of 4.0 I can't find the right 2.5
  11. Yes they said all I would have to do was change the outside harness fuel pump and motor brackets and sensors
  12. I found a motor for my jeep Comanche 86 tbi 2.5 but the motor i found is in a 95 jeep wrangler 2.5 fuel rail injector and when I try and research it and it says it possible ive got to change the ecu is this correct everything else looks about right and change the harness under the hood
  13. Its confusing lol I'm going to take pictures I for the love of figure the timing out ive got it dead on the camshaft and crankshaft markdown the compression stroke both valves closed and the distributor dead on at 4 and it still shows I'm out 10 degrees and it won't pull and then sometimes it will ideal just fine and when its dealing good it shows in time then it switches and starts missing and it shows out 10 degrees i don't understand this I'm a halfway decent mechanic and this thing is driving me crazy
  14. Cause the gentleman i got the truck apparently took a 95 jeep wrangler 2.5 tbi and stuck it in the 86 jeep Comanche and swap a few parts but done wrong so idk i guess ill try the 95 disturber and see
  15. Cause ive had nothing but trouble from this thing since ive gotten the one gentleman on here looked up the engine serial number and it came from a 95 jeep wrangler and the reason I done that was cause I couldn't get the timing to line up explains everything now though if noticed the wiring looked like it had been changed cause there's extra plugs here and there I'm going to look and see if there is a plug around the disturber cap
