PAULINO ENCISO Posted September 24, 2025 Share Posted September 24, 2025 Hello Team I am having several issues as lack of power and Shut Down by my Comanche after to drive some miles. I think the issue has been the computer. Do you know some place to get a reemplacement for 1992 Manual Version ? Link to comment Share on other sites More sharing options...
hgeranium Posted September 24, 2025 Share Posted September 24, 2025 52 minutes ago, PAULINO ENCISO said: Hello Team I am having several issues as lack of power and Shut Down by my Comanche after to drive some miles. I think the issue has been the computer. Do you know some place to get a reemplacement for 1992 Manual Version ? Are you 100% sure that it’s the computer? A 4.0 has many causes for the symptoms that you’ve explained. You can buy reman ECUs from any big box retail or online store, or preferably grab one from a junkyard. There should be a few years that have the same ECU that you need; someone smarter than me can tell you. Link to comment Share on other sites More sharing options...
amsuco Posted September 25, 2025 Share Posted September 25, 2025 Are you still running a cat? Having a plugged catalytic converter gave me those same symptoms. Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted September 25, 2025 Share Posted September 25, 2025 Check out car-part.com Don't know your engine size but any 92-94/95 xj with the same drivetrain should be fine for a donor pcm Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 25, 2025 Share Posted September 25, 2025 The most common cause of an issue like this would be a failing fuel pump. I would check your fuel pressure first before you buy a new computer. Fuel pumps are much cheaper than computers. Link to comment Share on other sites More sharing options...
