Dickinson County Comanche Posted September 19 Share Posted September 19 I was driving in town and was coasting down to a traffic light but wanted to put in some throttle to make the shift nicer, only to realize my engine had died. It did pop out the exhaust a little, which makes me think it was spark-related vs fuel related, especially since it died so quickly and suddenly. It started back up and idled at like, 2,000 rpm for maybe 10-15s then has run fine. Not down on power, no missing, popping, nothing. Back to normal. My guess is CPS, it’s original, but I tested it a few years ago and it tested fine, above the minimum voltage. Maybe it’s finally going out? It hasn’t had any issues with long crank/hot starts, and it wasn’t particularly hot when it died. I’m also suspect of the ASD relay, but I think that kills fuel, not spark. Not entirely sure, figured I’d get some inputs before shooting the parts cannon. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 19 Share Posted September 19 Check your manifold bolts they like to come loose and too much air when decelerating can cause the engine to shut off. Those loose bolts will also cause an intermittent high idle. Link to comment Share on other sites More sharing options...
hgeranium Posted September 24 Share Posted September 24 I agree with eagle on the manifold bolts. I made a post a few weeks ago about an intermittent high idle/rev on startup (eagle might have been the one to tell me to check it), and I tightened all the bottom manifold bolts that needed to be snugged. I'll never actually know if the problem is gone, only if it comes back, but as of now my startups have been much smoother and less aggressive. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted September 24 Share Posted September 24 I chased down my similar issue, with lots of help from the experts on this forum. You can follow the store at the link below if you like... Link to comment Share on other sites More sharing options...
