ratrapp Posted 19 hours ago Share Posted 19 hours ago I'm finally getting ready to put my 86 on the road monday.i had been just putting any random used battery i had laying around to get it started and running.i went and got a new group 58 battery yesterday because thats what according to all the parts stores that its what it takes.the 86 battery tray is different from the 87 -up trays.the 58 fits but it just doesnt seem right as it doesnt lock in the tray like its not the correst size.even my hold down bracket says standard and one size and heavy duty flipped over.curious to see what other 86 owners use for battery size.i can cut up the tray but would rather just get the right battery. Link to comment Share on other sites More sharing options...
coheed Posted 15 hours ago Share Posted 15 hours ago I have a group 34 in my 86 and it fits perfect. Can't remember which side I used on the hold down, but I am using the stock hold down block. Link to comment Share on other sites More sharing options...
eaglescout526 Posted 14 hours ago Share Posted 14 hours ago 32 minutes ago, coheed said: I have a group 34 in my 86 and it fits perfect. Can't remember which side I used on the hold down, but I am using the stock hold down block. You got a group 34 in yours? I wasn’t able to get one in my 84XJ Link to comment Share on other sites More sharing options...
coheed Posted 14 hours ago Share Posted 14 hours ago 5 minutes ago, eaglescout526 said: You got a group 34 in yours? I wasn’t able to get one in my 84XJ Technically a group 78, but same same. This is the interstate battery I have in there currently. This is the battery tray that was in the truck when I got it. I also have the tray out of my grandad's truck in the shed and it's the same style, even though this truck is a late 86 and my grandad's was an early production. Link to comment Share on other sites More sharing options...
coheed Posted 14 hours ago Share Posted 14 hours ago Actually, reading the specs I just realized it's a little wider and taller than the group 34s they offer, but an 1/8" shorter on the long side. Maybe that's why it fits and you couldn't get a group 34 in there? Link to comment Share on other sites More sharing options...
eaglescout526 Posted 13 hours ago Share Posted 13 hours ago 1 hour ago, coheed said: Actually, reading the specs I just realized it's a little wider and taller than the group 34s they offer, but an 1/8" shorter on the long side. Maybe that's why it fits and you couldn't get a group 34 in there? That’s probably why. But group 78 is good to know. Link to comment Share on other sites More sharing options...
ratrapp Posted 11 hours ago Author Share Posted 11 hours ago thanks guys,i 'm going to make the 58 fit but if the poor 2.8 survives long enough to outlast this battery ill go with a 34 or 78. Link to comment Share on other sites More sharing options...
coheed Posted 10 hours ago Share Posted 10 hours ago 3 hours ago, eaglescout526 said: That’s probably why. But group 78 is good to know. 1 hour ago, ratrapp said: thanks guys,i 'm going to make the 58 fit but if the poor 2.8 survives long enough to outlast this battery ill go with a 34 or 78. No problem. Also an fyi, the 78s are normally only side terminal batteries. The reason I got this one is it has both top and side terminals so it would be easier to connect a second battery or run power to my camper at some point. So, if you get a 78, make sure it works with whatever cable ends you have. Link to comment Share on other sites More sharing options...
ratrapp Posted 9 hours ago Author Share Posted 9 hours ago yeah you used a 78 dt which has both side and top terminals where a standard 78 has just side posts. Link to comment Share on other sites More sharing options...
