garyweb3 Posted June 21, 2025 Share Posted June 21, 2025 I planned on replacing my intake gasket on my 1987 Comanche w/2.5L engine. The first one I purchased has a foil surface on both sides. When I removed the manifolds I found a crack about 2/3's of the way around the exhaust manifold. I purchased a new replacement which came with a new combo manifold gasket. One side has the foil surface and the other side has a typical paper look. Which one is better if there is any difference and which surface goes toward the head? Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 21, 2025 Share Posted June 21, 2025 I’ve always had fitment and sealing issues with the full manifold gasket. Chrysler used the one piece for the intake manifold until 2001 when they stopped making the engine. I don’t recommend the full ones but, you already have them. Which ever one will fit best and work without any issue, run it. Neither surface makes a difference. Link to comment Share on other sites More sharing options...
garyweb3 Posted June 22, 2025 Author Share Posted June 22, 2025 That is the only gasket that comes up at either NAPA or RA. Link to comment Share on other sites More sharing options...
AZJeff Posted June 22, 2025 Share Posted June 22, 2025 The Chrysler factor gaskets for the 2.5 and 4.0 engines are not the most reliable in sealing the joint. (To put it in other terms, they suck.) I have used Remflex gaskets for years with no issues. Go to their website, and you will find ones for both of the MJ engines there. They are more expensive than OEM types but they don’t leak/fail with age. Link to comment Share on other sites More sharing options...
garyweb3 Posted June 22, 2025 Author Share Posted June 22, 2025 Thanks. I just did. Link to comment Share on other sites More sharing options...
