terryt Posted May 11, 2025 Share Posted May 11, 2025 I finally got my speedometer by grinding the cluster end shorter it was as close to perfect as I needed until it warmed up now it bounces again I assume I have to grind it shorter? If so how do I know how much without risking breaking that plastic clip? This is my 3rd cable and I’d rather not buy any more thank you in advance Link to comment Share on other sites More sharing options...
terryt Posted May 12, 2025 Author Share Posted May 12, 2025 Someone please help Link to comment Share on other sites More sharing options...
89 MJ Posted May 12, 2025 Share Posted May 12, 2025 How much does it bounce? Some of it will just be the nature of having a speedo cable. You could go with the boxy Jeep electric speedo conversion. https://boxyjeep.com/products/87-90-electric-speedometer-conversion-full-kit?variant=50337911210295 Link to comment Share on other sites More sharing options...
pizzaman09 Posted May 13, 2025 Share Posted May 13, 2025 Does your Jeep have a speed sensor for cruise control? It would be a sensor in line with the cable about 12 inches from the speedo connection. Link to comment Share on other sites More sharing options...
terryt Posted May 13, 2025 Author Share Posted May 13, 2025 it does not someone told me to grind the cable going into the cluster which i did and it was perfect until it warmed up then it started bouncing so they said to grind it some more because when it gets hot it swells up any thoughts? Link to comment Share on other sites More sharing options...
