Anthi4078 Posted April 8, 2025 Share Posted April 8, 2025 Hey everyone. So I was at work today looking at a rear fender liner for a newer dodge pickup, and it’s basically just a big plastic tub. It got me thinking if I could take one from some model of mini truck or something, and do a little trimming to get it to fit decent in the wheel wells. I haven’t looked into if any of the older mini trucks even came with plastic liners yet, but I figured I’d ask on here to see if anyone has done something similar or has any suggestions. Link to comment Share on other sites More sharing options...
pizzaman09 Posted April 9, 2025 Share Posted April 9, 2025 I'd buy a larger one from a squared off rear wheel liner truck. Then make one vertical cut to slide the two halves together, at the length of the Comanche rear wheel well. Over lap of the joint should have the one in the back of the truck under the half in the front of the truck due to water flow as it flings off of the tire. I'd use a good waterproof adhesive to bond the halves together. All other edges trim to fit. I like the idea of this project, I had considered making some myself but I hadn't considered modifying one until now. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 9, 2025 Share Posted April 9, 2025 Check out Gjeep’s build he cut down front liners which are readily available and they fit decently. Link to comment Share on other sites More sharing options...
