Gojira94 Posted March 8, 2025 Posted March 8, 2025 In front of, or through the middle of the fender braces?
llhat Posted March 8, 2025 Posted March 8, 2025 dunno for sure, but be sure to protect those wire in the lower image (driver's side?) not going to be near mine soon to try to look to see what factory did would make sense to not have them routed through the brace as harness would need to be 'un threaded' if you removed the brace.
Gojira94 Posted March 9, 2025 Author Posted March 9, 2025 Thanks, I will be dressing things up before it’s all done. Just in the fitting stage right now. I found an old pic from 2022 where I’d just taken off the header panel and it was just like this. That doesn’t mean it hasn’t been moved since 1987 though my concern was getting the header panel on without a struggle. I think I’ll be ok either way.
watchamakalit Posted March 9, 2025 Posted March 9, 2025 Just looked at mine, and they are routed just like what you have in the picture. That's not to saw mine hasn't been moved prior to my knowledge. But it's one more truck that backs up your thinking.
