ghetdjc320 Posted January 13 Share Posted January 13 I swapped to the larger 97+ XJ glass and picked up a set of prp belt line moldings (the ones that go horizontal above the door panel and above the door handle inside and out). I don’t have an oem XJ unit to compare it to but the trim is coming out about 1/2-5/8” short. I can start searching online for used oem ones but just want to verify the overall length if anyone has one lying around or on their 97+ XJ Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 13 Share Posted January 13 The 97+ mirrors have a larger mounting surface than the older mirrors and that might be why they look short. I think that for everything to line up properly you need all the window trim and the 97+ mirrors. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 13 Author Share Posted January 13 The cost to benefit ratio is not looking good for this swap to be done correctly. I think I’ll just go pickup some newer XJ doors Link to comment Share on other sites More sharing options...
watchamakalit Posted January 14 Share Posted January 14 On 1/13/2025 at 5:34 PM, ghetdjc320 said: The cost to benefit ratio is not looking good for this swap to be done correctly. I think I’ll just go pickup some newer XJ doors Expand Not what I want to hear. I was thinking about tackling this on mine. Maybe not.... Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted January 14 Share Posted January 14 One thing to keep in mind is, as far as I know you can't put the old door cards on the 97+ doors. Also I have heard with the door closed you won't be able to open the 96- glove box with the 97+ door cards. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 14 Author Share Posted January 14 I can live with the glove box not dropping fully. Link to comment Share on other sites More sharing options...
