Heath Posted December 3, 2024 Share Posted December 3, 2024 Project ‘Uncle Lou’… The goal of the project is for it to be a daily driver for my son (safe, reliable, etc.), and used for weekend camping and hunting adventures, in memory of a great friend ‘Uncle Lou’. I’m located in Fayette County, GA (south of Atlanta). This had been someone else's project before Uncle Lou acquired it. Once I got it, we had to do a few things to get it running – brakes, battery, spark plug wires, gas tank and sending unit. Other major components seemed ok. My current thinking is to address rust issues, replace required components – keeping with the classic Comanche look. The long story… Several years ago, my dad bought an old farm house with some hunting land in central Georgia – a family getaway for family and friends. One of his best friends, Lou from North Carolina, came often. One day Uncle Lou showed up with this old truck. This thing was/is crusty and roached out, but we all fell in love with it and it quickly became the go-to truck for anything and everything, from running to town for a bite to eat to ripping through red clay mud bogs, to crawling over dead-fall pines to retrieve a down deer, it took on anything we threw at it… Good times, great memories. That all started to slow down as Uncle Lou began having health issues. During that time, Uncle Lou couldn’t come out as often and he gave this truck to my dad. My dad eventually sold the property, and we didn’t have much use for the truck, so it sat… Uncle Lou’s health continued to decline and he passed away February of 2024. This project is in honor of Uncle Lou. I believe Uncle Lou got this truck from a neighbor in Fuquay-Varina, NC, where the neighbor had modified it into what it is now. It’d be awesome if it was one of y’all??!! Anyway, I’m no mechanic, I don’t really know what we have… From a vin lookup, it was originally 2wd. So, I know it’s been converted from 2wd to 4wd – I’m assuming a swap from a Cherokee XJ. The engine appears to be the original 4cyl, not sure about transmission and axles. Appears to be some swapping in the interior too. All major mechanical stuff works, exterior lights work, fairly road-worthy. Not sure about HVAC, seems we have some heat.... So, the work begins... Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 3, 2024 Share Posted December 3, 2024 If its been converted from 2 to 4wd, it should have either an AX5 5 speed or the AX4 4 speed manual with a 231 transfer case unless they went old and found a 207. On the off chance they found a 4cyl AW4 to throw in(stupid rare). Axles should be D30 front and D35 rear unless it has the metric ton package then it could have a D44 Link to comment Share on other sites More sharing options...
Heath Posted December 3, 2024 Author Share Posted December 3, 2024 LED tail lights... In case anyone else runs in to this... I added LED tail lights. All worked as expected except the blinkers - they didn't blink at first. I had to add an LED compatible relay. See pictures attached. I got the relay from NAPA, and it also required a ground, as you'll see in the pics - I created a longer jumper from the relay to a grounded bolt. All good now. Link to comment Share on other sites More sharing options...
Heath Posted December 3, 2024 Author Share Posted December 3, 2024 6 minutes ago, eaglescout526 said: If its been converted from 2 to 4wd, it should have either an AX5 5 speed or the AX4 4 speed manual with a 231 transfer case unless they went old and found a 207. On the off chance they found a 4cyl AW4 to throw in(stupid rare). Axles should be D30 front and D35 rear unless it has the metric ton package then it could have a D44 thanks for the reply, its a 4speed transmission. i'll try to find more identification... it drives quite 'low' as far as gearing goes, which is great given its for my 16 year old son to drive around town, as it won't hardly go over 45 mph! :-) Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 3, 2024 Share Posted December 3, 2024 4 speed would make it an AX4 manual. Thats just based on your photos above with the 3 pedals. Link to comment Share on other sites More sharing options...
Heath Posted December 3, 2024 Author Share Posted December 3, 2024 Had a very leaky valve cover, burning off dangerous amounts of oil! It has the plastic 2.5L cover, and the previous project owner had used some sort of liquid gasket sealant. I replaced it with NAPA VALVE CVR GASKET SET, Part #: FPG VS50245R, no more leaking... Link to comment Share on other sites More sharing options...
89 MJ Posted December 3, 2024 Share Posted December 3, 2024 Looks like you've got a 21 slot grille. That is very rare. Link to comment Share on other sites More sharing options...
Heath Posted December 3, 2024 Author Share Posted December 3, 2024 Replaced old brass radiator. First did a radiator flush with old radiator in place, to try to get as much of the impurities out of the system prior to installing the new radiator. Then replaced with a new aluminum radiator and thermostat with new gasket - all good so far... Radiator - LILAND GLOBAL Part# 871AA, Thermostat - CALORSTAT Part# TH137870 Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 3, 2024 Share Posted December 3, 2024 7 minutes ago, Heath said: plastic 2.5L cover, Looks like the terrible crown cover. IF it ever fails, ive got a couple hard OEM plastic covers. Or aluminum is a route to go too. Link to comment Share on other sites More sharing options...
Heath Posted December 3, 2024 Author Share Posted December 3, 2024 3 minutes ago, 89 MJ said: Looks like you've got a 21 slot grille. That is very rare. LOL! I recently got a new aftermarket, as y'all know they are cheap and readily available - pic coming up with the front end update status. But, good to know, as I still have the 21 slot, and will refurbish it and have it ready. Link to comment Share on other sites More sharing options...
Heath Posted December 3, 2024 Author Share Posted December 3, 2024 Front end with new/updated aftermarket parts... header panel, grill, headlight bezels, side markers, and freshened up bumper and end caps. Link to comment Share on other sites More sharing options...
Heath Posted February 17, 2025 Author Share Posted February 17, 2025 Replaced old windshield washer pump TRICO 11509 Link to comment Share on other sites More sharing options...
Heath Posted February 17, 2025 Author Share Posted February 17, 2025 Rusted out floor pans. Working on pulling up the longitudinal supports, drilling out spot welds, prying, cutting, repeat. Passenger side longitudinal support finally removed Link to comment Share on other sites More sharing options...
Heath Posted February 17, 2025 Author Share Posted February 17, 2025 New 31 x 10.50 tires! Part #Falken Wildpeak AT4W 31x10.50x15 And removable door mod. Removed fenders to make it easier to access hinges. Used a 10m ratchet wrench on a T40 bit. Checked the vehicle side of hinge and is in good shape - not loose and no broken welds. Cut the part of the door side hinge, and approximately 3/4" from bottom of hinge pin. Attached door side of hinges to the door Hinge mod finished and door back on Link to comment Share on other sites More sharing options...
Heath Posted February 17, 2025 Author Share Posted February 17, 2025 Swapped 88 gauge cluster with an 89 cluster (with fuel E/F indicator, tachometer) Link to comment Share on other sites More sharing options...
Heath Posted February 17, 2025 Author Share Posted February 17, 2025 Working on stripping old bed liner material a previous owner applied to the entire exterior/prepping for paint. Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 22, 2025 Share Posted February 22, 2025 This is an awesome and fast moving project, the weather must be good where you are at. Looking forward to Uncle Lou's new paint job. Link to comment Share on other sites More sharing options...
Heath Posted February 24, 2025 Author Share Posted February 24, 2025 Thanks! We're in Georgia, but had some cold weather recently and made room for it in the garage next to a buddy heater ;) Link to comment Share on other sites More sharing options...
Heath Posted February 24, 2025 Author Share Posted February 24, 2025 Progress on the floor pans! Dry fitting the passenger side. Very impressed with the fitment of the full length pans from Key Parts, floor contour and bolt holes line up very well. In the picture I have not bent, forced, cussed at, or relief cut anything, just simply placed everything in where it goes. (I still need to cut the floor out underneath it) Link to comment Share on other sites More sharing options...
Heath Posted February 24, 2025 Author Share Posted February 24, 2025 Progress with the seats! Mounted seat brackets (from Brandon Scarbrough) they are great - thanks Brandon! I used 1 5/8" x 13/16" 14 GA strut channel as the interface between the aftermarket bucket seats and the brackets, and the brackets fit perfectly into the floor studs. This made it easy to adjust the seat left/right for proper clearance. Dry fitted the seat. It is so nice and comfortable! In one of the pics I tried to show how the seating height is actually almost identical to the OEM buckets - even with the strut channel sitting between the seat and brackets. Link to comment Share on other sites More sharing options...
Heath Posted February 24, 2025 Author Share Posted February 24, 2025 Deleted Dana 30 Central Axle Disconnect (CAD). Part # Alloy USA Differential Lock Kit for Jeep Wrangler/Cherokee | Permanent Replacement | 451100 Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 28, 2025 Share Posted February 28, 2025 That is a nice looking CAD delete kit. Link to comment Share on other sites More sharing options...
Heath Posted February 28, 2025 Author Share Posted February 28, 2025 1 hour ago, pizzaman09 said: That is a nice looking CAD delete kit. Link to comment Share on other sites More sharing options...
