coheed Posted Tuesday at 04:13 PM Share Posted Tuesday at 04:13 PM Seeing if I can make my life easier than recreating these sections of my firewall. If anyone has a parts truck I'd like to get basically the whole driver's side from the floor pan to the cowl between the frame and the A-pillar. The passenger I'd just need the corner bit under the blower and coolant line areas and the like corner spot where the floor pan meets the firewall and A-pillar. Link to comment Share on other sites More sharing options...
The86manche Posted Tuesday at 04:32 PM Share Posted Tuesday at 04:32 PM Key parts sells the full length floor pans for our trucks. Not firewall metal though. But easy enough to recreate. Or get from a cherokee because it's the same up until 96 I believe Link to comment Share on other sites More sharing options...
coheed Posted Tuesday at 05:37 PM Author Share Posted Tuesday at 05:37 PM 1 hour ago, The86manche said: Key parts sells the full length floor pans for our trucks. Not firewall metal though. But easy enough to recreate. Or get from a cherokee because it's the same up until 96 I believe Yeah I've already got both full pans and the braces from them. I'm just trying to save myself some time if someone had a truck they could cut some good pieces out of. Link to comment Share on other sites More sharing options...
88mjsally Posted 16 hours ago Share Posted 16 hours ago I have a 93 2 door xj I am about to crush if that would help. I’m not all that far from you either (about 3 hours). I’ll have to make sure there’s no rust there but I’m pretty sure it’s solid Link to comment Share on other sites More sharing options...
coheed Posted 9 hours ago Author Share Posted 9 hours ago 6 hours ago, 88mjsally said: I have a 93 2 door xj I am about to crush if that would help. I’m not all that far from you either (about 3 hours). I’ll have to make sure there’s no rust there but I’m pretty sure it’s solid Yeah I'd be interested if it's good and you're willing to cut it out. Link to comment Share on other sites More sharing options...
88mjsally Posted 8 hours ago Share Posted 8 hours ago 41 minutes ago, coheed said: Yeah I'd be interested if it's good and you're willing to cut it out. It looks good from the firewall side. I don’t have the carpet out currently. I was going to offer the pieces you needed free if you cut them out Link to comment Share on other sites More sharing options...
