Ken Seymour Posted October 6, 2024 Share Posted October 6, 2024 I need some help. The previous owner completely destroyed the cable and I need repair it or replace it. Both ends are torn out of the connector. The inner cable is fine. I have been searching for a replacement but I'm confused. Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 6, 2024 Share Posted October 6, 2024 Search for a 1990 Cherokee cable. It is the exact same. Just make sure you get the right length like 2wd vs 4wd. Link to comment Share on other sites More sharing options...
87MJTIM Posted October 6, 2024 Share Posted October 6, 2024 also, does yours have cruise or not? Different ends toward the cluster. Link to comment Share on other sites More sharing options...
Ken Seymour Posted October 6, 2024 Author Share Posted October 6, 2024 37 minutes ago, 87MJTIM said: also, does yours have cruise or not? Different ends toward the cluster. 2WD short bed no cruise. It's a base. No carpet. My original cable is a about 72". I found one on eBay 53006182. The fool is trying to get 25 dollars for it. The white plastic speedometer end has one side missing. Worst case scenario I will have to machine up some reinforcements for the ends and fix it. Link to comment Share on other sites More sharing options...
Gojira94 Posted October 6, 2024 Share Posted October 6, 2024 I think this is what you're after: Pioneer Speedometer Cable CA-3116 Notes: Speedometer Cable. 77" Length. Without Cruise Control. Plastic clip in at speedo head $45.99 at Autozone Listed at Autozone for 4.0 / 4WD but parts house websites are often wrong by application. There's also this one: Pioneer Speedometer Cable CA-3068 Notes: Speedometer Cable. 94" Length. Without Cruise~Control. Plastic clip in at speedo head (I'd guess this one is made with extra length to fit both 2WD and 4WD) $36.99 at Autozone Link to comment Share on other sites More sharing options...
Ken Seymour Posted October 6, 2024 Author Share Posted October 6, 2024 Thank you all for your help. I think the guy that writes the description for the automotive websites should be fired. It shouldn't be confusing. I'll get one ordered. Thanks again Link to comment Share on other sites More sharing options...
