JoeM88 Posted September 11, 2024 Posted September 11, 2024 Hey guys I bought a pair of rear mudflaps and then realized they belong to an xj. Would anyone of you have an mj rear template with measurements that I could use? Thanks!
Eagle_SX4 Posted September 11, 2024 Posted September 11, 2024 This might help. Not a template but a good place to start.
JoeM88 Posted September 11, 2024 Author Posted September 11, 2024 Thanks Eagle I did see that and it helps. That left corner piece is a little tricky.
JoeM88 Posted September 11, 2024 Author Posted September 11, 2024 I made the template and it works but I’d have to cut 2 inches off the bottom. if anyone has a pair of rear mud flaps please let me know thanks!
eaglescout526 Posted September 12, 2024 Posted September 12, 2024 10 minutes ago, JoeM88 said: I made the template and it works but I’d have to cut 2 inches off the bottom. Why? You’re not looking for exact size and shape of the MJ flap are ya? You might be searching for a while to find a set for the MJ. I recall someone on here actually used XJ rears on the MJ and had no complaints. I’ll find it later this evening for ya.
TexanEliminator Posted September 26, 2024 Posted September 26, 2024 I have a NOS front and rear I’ll take $400 for if you’re interested
