Misc 85/88 interior mj xj pieces
The86manche
Looking to sell the haul from my junkyard crawl.
Mainly picked these pieces up to give back to the community, otherwise they would be crushed and lost forever.
88 xj power door cards. Driver backing has some water damage but still in good shape. I have the Hockey stick arm rests that go with them. And if you know what you are doing you could easy modify them for window cranks.
$200 with the arm rests or $150 for the cards. -DOOR CARDS SOLD
hockey stick arm rests -$75
Hockey stick arm rest clips $20
3/4 cluster in okay condition from an 85 with a 2.8. Missing the trip Reset nob and the lense is broken. Mounting tabs okay though. $60
Porno red window crank handles with the rings $25 each or $40 for the set one is sun faded.
Porno red sun visor clips $30
Factory color matched side mirror cover bezel. Only have the left. $30
Set of factory front mud guards in decent shape. Some scuffs. $100
Located in mass, all are obo, and willing to ship. Thanks for looking :))
11 hours ago, schardein said:
FYI, if you put manual window cranks on those door panels. the window crank will hit the Jensen speaker grills.
Good to know, I actually didn't consider that. On the plus side. The speaker grills are screwed in so they could be removed/ replaced for a remedy :L:
Yes the generic style speaker grills found on many XJ/MJ door panels have a lower profile.
I could be wrong, but I don't think the factory Jensen sound system was available with manual crank windows for this reason.
Archived
