tkgibbs27 Posted January 6, 2008 Posted January 6, 2008 what is needed exactly to do this? and how much do you guys think it would cost?
Pete M Posted January 6, 2008 Posted January 6, 2008 - 4wd transmission that matches your engine's bolt pattern - t-case that matches your transmission's spline count - Dana 30 front axle that matches the rear axle's gear ratio (not necessarily what you have now, but they have to match) - front driveshaft of the correct length - rear driveshaft of the correct length - all the t-case shifter assembly stuff (don't forget the little linkage pivoting bracket that attaches to the underside of the body) Cost is entirely dependent on you. Some guys have purchased whole vehicles for $200, other's can spend thousands building up the individual parts.
tkgibbs27 Posted January 7, 2008 Author Posted January 7, 2008 well finding a 4.0L with 4wd over here is almost like finding a needle in a hay stack. it's possible, though there aren't that many listings, especially within a reasonable price range and stock without any lifts or other mods that would bring someone to increasing the price. but anways, i found an '89 mj over in portland, oregon for 950$ but it doesn't have 4wd.
Pete M Posted January 7, 2008 Posted January 7, 2008 Myself, I prefer to pick and choose the parts. That way I get the best of the best, rather than simply what Jeep used back in the day. This is what I have in my 90 (which technically was 4wd to begin with, but I've replaced everything but the engine and trans): --97+ Cherokee Dana30 (because it has the bigger 297 joints on no CAD and is new enough that a complete overhaul wasn't necessary) --MJ/XJ Dana 44 --95+ bellhousing for the AX-15 (external slave) --NP-242 t-case (for fulltime capability)
tkgibbs27 Posted January 7, 2008 Author Posted January 7, 2008 i am looking at these two mj's right now. http://portland.craigslist.org/mlt/car/525366864.html http://boise.craigslist.org/car/529915824.html i am waiting to see what the one in boise looks like before i make a decision on that one. first of all i have to sell my truck first, hopefully i can do it before either of these guys sell these mjs. i would like to get the one in boise so i don't have to deal with converting. and i would have some money to fix anything up that needs to be. plus it's a long bed and that's a must for me for my future plans. the difficult thing is trying to find a canopy that fits the damn thing.
tkgibbs27 Posted January 13, 2008 Author Posted January 13, 2008 - 4wd transmission that matches your engine's bolt pattern- t-case that matches your transmission's spline count - Dana 30 front axle that matches the rear axle's gear ratio (not necessarily what you have now, but they have to match) - front driveshaft of the correct length - rear driveshaft of the correct length - all the t-case shifter assembly stuff (don't forget the little linkage pivoting bracket that attaches to the underside of the body) Cost is entirely dependent on you. Some guys have purchased whole vehicles for $200, other's can spend thousands building up the individual parts. do any of you guys have any of this laying around. if you guys do you should put a price on the items so i know what i would be working with.
CWLONGSHOT Posted January 13, 2008 Posted January 13, 2008 BTW.. you do NOT NEED a Mj to do this!!! Look for XJ's!!! Cheaper and WAY WAY more plentiful!!! CW
JeepcoMJ Posted January 13, 2008 Posted January 13, 2008 BTW.. you do NOT NEED a Mj to do this!!! Look for XJ's!!! Cheaper and WAY WAY more plentiful!!! CW exactly all parts would be $500 MAX if you buy a similar year and transmission-equipped cherokee. the ONLY thing that would be different then, would be the rear driveshaft. and that will cost $90 or so to get shortened.
CWLONGSHOT Posted January 13, 2008 Posted January 13, 2008 GOOD CATCH PAT!!! :cheers: Yea the XJ drive shaft for the rear is different legnth. But as Pat said, you could get yours shortened (Likely locally) pretty cheaply. :D CW
JeepcoMJ Posted January 13, 2008 Posted January 13, 2008 GOOD CATCH PAT!!! :cheers: Yea the XJ drive shaft for the rear is different legnth. But as Pat said, you could get yours shortened (Likely locally) pretty cheaply. :D CW thanks a tip; use your comanche shaft and have it shortened. having a shaft shortened is MUCH cheaper than having one retubed (i.e. having a cherokee one lengthened)
tkgibbs27 Posted January 13, 2008 Author Posted January 13, 2008 just looking into it. i am working out a decision between two different mj's right now. one of them doesn't have 4wd. better shape than the one with 4wd but more money is wanted. think i will get the one with 4wd already and fixer up.
comancheon33 Posted January 13, 2008 Posted January 13, 2008 Costs me 100 bucks to have an XJ driveshaft retubed to fitan MJ everytime. I have done this twice now. Both time the factory shaft was the rubber filled POS.
tkgibbs27 Posted January 22, 2008 Author Posted January 22, 2008 does the year of the xj matter for using the parts?
Geonovast Posted January 22, 2008 Posted January 22, 2008 Not really. My red 91 has a transmission from an 86 XJ and the front axle is from a 94.
tkgibbs27 Posted January 22, 2008 Author Posted January 22, 2008 ok. so you can use all the parts from the donor to convert it to a 4wd? is there anyone around close to me that has done this conversion before?
Geonovast Posted January 22, 2008 Posted January 22, 2008 Yes, the only thing you cannot use from the donor is the rear driveshaft. XJ shafts are way too short.
tkgibbs27 Posted January 22, 2008 Author Posted January 22, 2008 alright. how do you come across getting one the right size? do you gotta have it lengthened?
Geonovast Posted January 22, 2008 Posted January 22, 2008 You'll have to do measurements, and I would recommend getting your current rear one shortened.
tkgibbs27 Posted January 23, 2008 Author Posted January 23, 2008 what's the gear ratio for the dana 44s they put in the 89 mj's?
Geonovast Posted January 23, 2008 Posted January 23, 2008 Depends on the motor, tranny, and packages. Generally speaking, Jeeps did this. 4.0 + 5 speed = 3.07 4.0 + Auto = 3.55 2.5 + 5 speed = 4.10 2.5 + 4 speed = 3.55 2.5 + auto = 4.10 Not sure what they did with the 2.8, but I know 3.73 was also an option. Just look at the tag on the diff. If all it gives you is gear tooth numbers, take the ring number divided by the pinion number.
tkgibbs27 Posted January 23, 2008 Author Posted January 23, 2008 well the one i am working on getting is a 4.0 5speed. only 2wd so i need to get all this info gathered up on converting. so i know what to get. haven't seen to many cherokee's close by that are 4wd for a low enough price.
tkgibbs27 Posted January 23, 2008 Author Posted January 23, 2008 w/o vacuum disconnect; w/ABS; 3.07 ratio w/o vacuum disconnect; w/o ABS; 3.07 ratio - only one they have at the junk yard: 1991, 1993, 1999 years. w/vacuum disconnect, 3.07 ratio
Geonovast Posted January 23, 2008 Posted January 23, 2008 Wait...so you don't have the truck you're converting yet?
tkgibbs27 Posted January 23, 2008 Author Posted January 23, 2008 it's not in my hands yet. but the guy is keeping it for me until i can pay it off. so it will be mine here soon. a friend of mine is getting me a job working for the carpenters union and i believe the wages are around 20+ dollars an hour. he said i will be worth up to 10 hours, but only four days a week. which is fine with me. like i said. i am trying to get all this info gathered up now.
Geonovast Posted January 23, 2008 Posted January 23, 2008 Gotcha. I'd get the non-disco without ABS. But that's me.
