Turbine Wheel Center Cap Repair
Has anyone found a way to fix/replace broken tabs on the backside of the center cap ? I have a couple of caps with 2 or 3
missing tabs each. Does anyone have any successful  experience using the caps with a few missing tabs ?
You can probably plastic weld the broken tabs from the inside with a soldering iron. I have not done it to the caps myself, but I've had success repairing other plastic parts across the comanche with that method. Worth a shot. If you don't have the broken bits, CAD something similar up and 3D print it in ABS, then try plastic welding. No one ever sees it, so it does not have to look pretty.
Thanks for the replies. The broken tabs are missing, so I will have to get creative to replace them. These are getting scarce and kinda pricey. I am trying to avoid
loosing one going over a neighborhood speed bump,
  • 1 month later...
