Gojira94 Posted Monday at 06:25 PM Share Posted Monday at 06:25 PM (edited) In looking for ride height, I found THIS thread, in which a member asked "This may be a stupid question but why is does one say front : 7.75 rear : 9.2 and the second answer say front: 6.75 and rear: 6" . Does anyone know or know how to find out what the 2-letter codes translate to? I ask because I'm setting wheelbase at what will be on a 6" lift and wondered what the difference is that makes the 4WD ride height 1" higher than 2WD. These differences, according to what @Eagle shared as "...M.R. 277 for the Comanche, I.S. Notes. Specifically, it's in I.S. 14E, which addresses spring identification and selection." Mainly, I'd like to know if it's just coil and leaf spring differences (taller/ more) and just explains how much more spring is needed to make that 1" difference in all the combinations of engine/ transmission/ transfer case, rear axle, short vs long wheelbase, etc. Parts Catalog list (38 different coil springs): 8 52001107 SPRING, Front Light Duty, Coded EF Require Quantity: 2 8 52001108 SPRING, Front Light Duty, Coded EG Require Quantity: 2 8 52001109 SPRING, Front Light Duty, Coded EH Require Quantity: 2 8 52001110 SPRING, Front Light Duty, Coded EJ Require Quantity: 2 8 52001111 SPRING, Front Light Duty, Coded EK Require Quantity: 2 8 Jeep 52001114 52001114 SPRING, Front Standard Duty, Coded FE Require Quantity: 2 Package Quantity: 1 8 Jeep 52001115 52001115 SPRING, Front Standard Duty, Coded FF Require Quantity: 2 8 Jeep 52001116 52001116 SPRING, Front Standard Duty, Coded FG Require Quantity: 2 Package Quantity: 1 8 Jeep 52001117 52001117 SPRING, Front Standard Duty, Coded FH Require Quantity: 2 8 Jeep 52001118 52001118 SPRING, Front Standard Duty, Coded FJ Require Quantity: 2 8 Jeep 52001119 52001119 SPRING, Front Standard Duty, Coded FK Require Quantity: 2 8 Jeep 52001122 52001122 SPRING, Front Heavy Duty, Coded GF Require Quantity: 2 Package Quantity: 1 8 Jeep 52001123 52001123 SPRING, Front Heavy Duty, Coded GG Require Quantity: 2 Package Quantity: 1 8 Jeep 52001124 52001124 SPRING, Front Heavy Duty, Coded GH Require Quantity: 2 8 Jeep 52001125 52001125 SPRING, Front Heavy Duty, Coded GJ Require Quantity: 2 8 52001784 SPRING, Front Light Duty, Coded EL Require Quantity: 2 8 52001785 SPRING, Front Light Duty, Coded EM Require Quantity: 2 8 52001786 SPRING, Front Light Duty, Coded EN Require Quantity: 2 8 52001787 SPRING, Front Light Duty, Coded EP Require Quantity: 2 8 52001788 SPRING, Front Light Duty, Coded ER Require Quantity: 2 8 52001789 SPRING, Front Standard Duty, Coded FL Require Quantity: 2 8 52001790 SPRING, Front Standard Duty, Coded FM Require Quantity: 2 8 Jeep 52001791 52001791 SPRING, Front Standard Duty, Coded FN Require Quantity: 2 Package Quantity: 1 8 Jeep 52001792 52001792 SPRING, Front Standard Duty, Coded FP Require Quantity: 2 8 Jeep 52001793 52001793 SPRING, Front Heavy Duty, Coded GK Require Quantity: 2 8 Jeep 52001794 52001794 SPRING, Front Heavy Duty, Coded GL Require Quantity: 2 8 52001795 SPRING, Front Heavy Duty, Coded GM Require Quantity: 2 8 52001796 SPRING, Front Heavy Duty, Coded GN Require Quantity: 2 Edited Thursday at 05:00 PM by Gojira94 Link to comment Share on other sites More sharing options...
eaglescout526 Posted Monday at 06:27 PM Share Posted Monday at 06:27 PM Oh hey! Welcome to the mystery I’ve been trying to understand since ‘19. Link to comment Share on other sites More sharing options...
Gojira94 Posted Monday at 06:39 PM Author Share Posted Monday at 06:39 PM 2 minutes ago, eaglescout526 said: Oh hey! Welcome to the mystery I’ve been trying to understand since ‘19. Crap. This from a guy who had access to all the old tomes in the Chrysler dealership network for a long time... I'm screwed lol. Wish I knew C++ or C# better, I could generate the number of combos of wheelbase, drivetrain and 2WD/4WD. I bet it'd be around 35-40. More modern XJs and probably the 90-92 MJs build sheets list things like SDA, SDU, etc. for standard/ heavy duty suspension options. I bet the 2-letter codes from the AMC era are equivalent, but nobody we know has the decoder ring. Suffice it to say I suppose it was arbitrarily decided by AMC/ Chrysler design engineers that 4WD offerings should have an additional 1" of ride height/ ground clearance. And I also suppose that's all I need to know to set my ride height and wheelbase on my project, based on the amount of lift I'm adding. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Monday at 07:13 PM Share Posted Monday at 07:13 PM lol. Yeah I scoured alllllll over ever piece of media I could get my hands on to find this info. Got nothin. If I had to say there’s probably two sections for the springs. One set is 2wd, the other is 4wd. Divided up by both wheel base and duty and engine probably into the mix. Chances are they could also be ratings too. So say from the manufacture and AMC put together a specific set of ratings of pounds for each spring for each code. It is without a doubt a great question as to why so many codes for something simple as three categories of light, standard and heavy duty springs. Link to comment Share on other sites More sharing options...
Eagle Posted Thursday at 04:12 AM Share Posted Thursday at 04:12 AM On 6/24/2024 at 2:39 PM, Gojira94 said: Suffice it to say I suppose it was arbitrarily decided by AMC/ Chrysler design engineers that 4WD offerings should have an additional 1" of ride height/ ground clearance. And I also suppose that's all I need to know to set my ride height and wheelbase on my project, based on the amount of lift I'm adding. No. It isn't purely 2WD vs. 4WD. And it may be different for XJs vs. MJs. My first Jeep in this type was an '88 XJ Pioneer. I special ordered it, with 4WD and a "heavy duty" suspension, but no off-road package. Ride height, even with the stiffer springs, is the standard XJ height, not the +1 inch that in later years became known as the "Up Country" package. In the MJ, however, I think it may be correct that 4WD models ride higher than 2WD models. Unfortunately, I have never bought a new MJ, so I don't really have any valid frame of reference other than the technical bulletin I cited and which was quoted above. Link to comment Share on other sites More sharing options...
Gojira94 Posted Thursday at 04:57 PM Author Share Posted Thursday at 04:57 PM 12 hours ago, Eagle said: In the MJ, however, I think it may be correct that 4WD models ride higher than 2WD models. Unfortunately, I have never bought a new MJ, so I don't really have any valid frame of reference other than the technical bulletin I cited and which was quoted above. Fair enough, as good information as I could ask for. I think what I need to do is double check my shock travel numbers, bumpstop distances and decide on front height of 12.75", 13.75" or in between for my 6"-ish lift. Thank you for chiming in. Link to comment Share on other sites More sharing options...
