ja_racing Posted June 13, 2024 Share Posted June 13, 2024 Have a 88 mj speedometer jumps while going 30 jumps from 25-35 thought it was the speedometer cable installed new one and still the same any help Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted June 13, 2024 Share Posted June 13, 2024 The inner cable that spins is probably to long. This happened on my Eagle after I put in an after market cable. I fixed it by grinding the end of the inner cable down about 1/8 of an inch with a flap disc on an angle grinder. Link to comment Share on other sites More sharing options...
ja_racing Posted June 13, 2024 Author Share Posted June 13, 2024 1 minute ago, Eagle_SX4 said: The inner cable that spins is probably to long. This happened on my Eagle after I put in an after market cable. I fixed it by grinding the end of the inner cable down about 1/8 of an inch with a flap disc on an angle grinder. On which side cluster side or t case? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted June 13, 2024 Share Posted June 13, 2024 Both ends of my after market cable were metal so I could trim either end. I trimmed the speedo end. But if yours has a plastic tip on the speedo side like they were from the factory trim the t case side. Also do you have cruise control? If you do then you should have a 2 speedometer cables a short and a long. If you don't have cruise then you will only have one long one. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted June 13, 2024 Share Posted June 13, 2024 Also don't just trim off an 1/8 inch in one go. Just do a little at a time and then test it out. It may take a few tries but it is the safer way to do it. Link to comment Share on other sites More sharing options...
ja_racing Posted June 13, 2024 Author Share Posted June 13, 2024 4 minutes ago, Eagle_SX4 said: Also don't just trim off an 1/8 inch in one go. Just do a little at a time and then test it out. It may take a few tries but it is the safer way to do it. Ok ill give that a try no cruise its 1 cable ill try that tomorrow thanks for the help i was thinking it was the actual speedometer but ill try the cable first Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 15, 2024 Share Posted June 15, 2024 I've had this jumping around issue since I installed cruise control. I'll have to try out shortening the inner cable some. Link to comment Share on other sites More sharing options...
Eagle Posted June 15, 2024 Share Posted June 15, 2024 On 6/12/2024 at 11:17 PM, ja_racing said: Have a 88 mj speedometer jumps while going 30 jumps from 25-35 thought it was the speedometer cable installed new one and still the same any help First, remove the new cable and get some lubricant into it. If it's possible to slide the inner cable out of the sheath, wipe it down with a light, non-hardening grease or a quality synthetic oil. Second, check the routing of the cable. Often, jumping is a result of a tight radius bend somewhere in the routing of the cable beteween the speedo and the transmission or transfer case output. Link to comment Share on other sites More sharing options...
