Top C Posted June 9, 2024 Share Posted June 9, 2024 I need to replace the floor pan on drivers side of 87 MJ. I need to know a good quality place to purchase a replacement? I google it and I came up C2C is a good quality pan? Also I want to seal the joints what is the best sealant for this job? Thanks Mike Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted June 9, 2024 Share Posted June 9, 2024 I have one from C2C. A couple years ago it was pretty obvious by comparing C2C to Key parts panels that the KP fit better, and likely was superior. I was settled in KP until I noticed that the one sold on C2C looks very similar. It was a little cheaper too, so I bought it and it seems okay to me. For sealer, I bought two tubes of a seam sealer at O Reilly's. I forget the brand name, I believe it started with 'U' and it came packaged in a violet tube. There's other brands to try also. Link to comment Share on other sites More sharing options...
Top C Posted June 9, 2024 Author Share Posted June 9, 2024 Okay thank you for the info. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted June 9, 2024 Share Posted June 9, 2024 Key parts is the one to get still. C2c copied the key parts XJ floor pan which is what we all had to use previously but now they have the MJ specific pan. Brushable seam sealer is what the factory used around the floor pan joints. Link to comment Share on other sites More sharing options...
Top C Posted June 9, 2024 Author Share Posted June 9, 2024 Key parts do you have a link for them? Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted June 10, 2024 Share Posted June 10, 2024 6 hours ago, Top C said: Key parts do you have a link for them? First you need to determine if you need a full floor pan or just a half. I only needed a half myself a few patches. I have a few Key Parts pieces for other areas and I've always bought them on eBay. Would you care to provide pictures of your truck's floor? Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 10, 2024 Share Posted June 10, 2024 A good dryer or washer will do good for repair panels if your in a financial pinch. Link to comment Share on other sites More sharing options...
