Transfer case vent tube???
My 99 TJ AX-15 has a small breather cap on the top right behind the shifter. It's the kind of breather cap that prevents splashing from entering the hole. Likely not very effective if you submerge the whole truck, but I left it as is since it's so high up on the trans. I ran hoses from my t-case and axles up to the engine compartment and into a small valve cover filter assembly.
