eaglescout526 Posted January 25, 2024 Share Posted January 25, 2024 First, Ωhm ive dug through the electrical manual and for the life of me I cannot find this one wire on C104 at cavity F, blue wire. Have no idea where it leads I suspect C103 or C105 Anyone with an 86 4.0L, can I get some help on seeing where this one wire goes? I have my doubts I need it but I dont want to remove it if I find out I will need it later on. C104 is a ten wire connector that looks different from the rest at the passenger side by the shock tower or relay center. I will follow up if I need to figure out where any others go. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 25, 2024 Share Posted January 25, 2024 In the 87 electric manual, page 20, lower left of the ECU, Sync Ground. From C104, to C105, to C231. (Double check the wiring. I have found the manual to less than 100% accurate.) Link to comment Share on other sites More sharing options...
Ωhm Posted January 25, 2024 Share Posted January 25, 2024 Your right about accuracy. 88Elect Manual calls circuit SYNC Supply 7.1V. I do believe 88 corrected mistakes made in the 87 manual. Still both 87&88 show C104_F to C201_C16 as being part of the Engine Harness (E) while actually its part of the Engine Control Harness (EC). Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 25, 2024 Author Share Posted January 25, 2024 3 hours ago, 87MJTIM said: In the 87 electric manual, page 20, lower left of the ECU, Sync Ground. From C104, to C105, to C231. (Double check the wiring. I have found the manual to less than 100% accurate.) Ok good I can delete this wire. Thank you so much! I must’ve glossed over that when searching. Link to comment Share on other sites More sharing options...
