acfortier Posted January 1, 2024 Share Posted January 1, 2024 Has anyone mounted an amp to the back carpet panel? How did you do so? I'm debating whether or not I need to cut a piece of plywood to act as backing since that panel can't really hold any weight on it's own. Also debating mounting the amp behind the passenger seat floor, as well. This post has some pictures, but unclear what's behind it: Link to comment Share on other sites More sharing options...
Smokeyyank Posted January 1, 2024 Share Posted January 1, 2024 I used this one. It's small enough to go behind the driver seat. https://soundstream.com/product/pn5-640d/ If you want to mount to the back board you should reinforce it if you're putting a big amp. For a smaller one probably be fine. Link to comment Share on other sites More sharing options...
acfortier Posted January 1, 2024 Author Share Posted January 1, 2024 I have a Crunch P4125 that I had in an old truck that I was going to re-use--it's decently sized. I think I'm going to cut a piece of plywood to fit behind the passenger's side and mount it to the carpet panel so it's at least reinforced. Is that amp just floating behind the driver's seat? Link to comment Share on other sites More sharing options...
Smokeyyank Posted January 2, 2024 Share Posted January 2, 2024 7 hours ago, acfortier said: Is that amp just floating behind the driver's seat? Kind of, it's screwed "in" to the carpet. Didn't want to drill through the floor. Link to comment Share on other sites More sharing options...
acfortier Posted January 7, 2024 Author Share Posted January 7, 2024 Ended up buying a piece of project plywood and cutting it to fit, so I would have something to screw the amp to. Worked out great. Used some double-sided hook velcro strips to just hold the sub up against the carpet panel. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 7, 2024 Share Posted January 7, 2024 Start saving up for hearing aids now. Link to comment Share on other sites More sharing options...
