ashtonmj1 Posted November 15, 2023 Share Posted November 15, 2023 How did you upgrade your fuel pump to run the stock ls how did you upgrade the gauge with a t5 transmission the driveshaft can I reuse it or is there another one that will work it a t5 transmission rwd with a ford 8.8 short bed? Link to comment Share on other sites More sharing options...
Pete M Posted November 15, 2023 Share Posted November 15, 2023 I'd just plan on getting a new driveshaft made. it'll be stronger and exactly the right length. Link to comment Share on other sites More sharing options...
ashtonmj1 Posted November 15, 2023 Author Share Posted November 15, 2023 Thanks you Link to comment Share on other sites More sharing options...
Pete M Posted November 15, 2023 Share Posted November 15, 2023 On 11/15/2023 at 10:50 AM, ashtonmj1 said: Thanks you Expand there are several V8 swapped trucks in the Hardcore Tech subforum. Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted November 15, 2023 Share Posted November 15, 2023 Fuel pump isn't too hard a problem to resolve. Just adapt a higher rated fuel pump into your existing sending unit. Just Google research a bit under the criteria of jeep MJ LS swap fuel pump and I'm sure you can figure it out. Mine currently is setup with a fuel cell and inline walbro pump. Eventually I'd like to get this TJ tank and pump setup fitted to my liking and run that but what I have works for now Link to comment Share on other sites More sharing options...
