ashtonmj1
Everything posted by ashtonmj1
  1. Replaced the sending unit and it run fine now
  2. Found out my pump caught on fire in side my tank
  3. I have both turn signals, tail lights and reverse lights but no brake lights I have power to the connector under bed but no power at the socket win I hit the brakes but it powers win I hit the turn signals
  4. I think it's maybe the ballast resistor
  5. I was starting the truck and it would not start so I opened the hood and found this orange wire was burned up so I jumped it and now it won't even turn over 1988 jeep comanche 4.0
  6. How did you upgrade your fuel pump to run the stock ls how did you upgrade the gauge with a t5 transmission the driveshaft can I reuse it or is there another one that will work it a t5 transmission rwd with a ford 8.8 short bed?
  7. ok thanks
  8. do i need to strengthen the stock frame it dose not have any rust and keeping it rear wheel drive?
  9. I need help with my 87 2.5l comanche, when I turn the key to start the engine, the fuel pump runs, but the starter and spark plugs don't work, we tried to push start it and that didn't work, I jumped the starter and it spun the motor but it didn't fire, then took a volt meter and the plugs have power the relays have power 20230824_152454.mp4
  10. Where dose this line go? 2.5l 87 The one on the bottom of the throttle body
