1988 jeep comanche pioneer olympic edition
Luis
This is my Comanche Pioneer 1988,4.0L V6 , Olympic Edition.
I got from  a  junkyard  in Feb 2022. Richmond Virginia.
Fixed:
New:
Gas Tank
Gas Pump.
Water Pump.
Colling Tank.
Thermostat
Radiator.
Cooling Hoses.
Water Tank.
Fuel regulator
Fuel Pressure regulator
2- Transmission Oil Cooler Hose Assembly
Throttle Position Sensor
Power Steering Pump
Piston Ring
Timing Chain
Rod Bearing
Belt
Power Steering Pump Pulley
Belt Tensioner Pulley
Drive Belt Idler Pulley Compatible
Heater Blower
Heater Core
Rough Country shocks
Coil Spring
Rear Vacuum Harness
Front Vacuum Harness
Rough Country Daytona Steel Wheel Black
Rough Country N3 Steering Stabilizer
Steering Track Bar
LED Headlights
Haedline.
Cluster light.
Fornt Bumper Rough Country for Jeep Wrangles with aparters .
Rear Bumper Rough Country for Jeep Wrangler.
Original conditions:
TODAY : Oct/23:
