INSANE OIL PRESSURE GUAGE?
The oil pressure gauge  on my 86 is erratic, to say the least.  It will record a normal temperature for a while, then it goes wild, like a magnetic compass would if you surrounded it with magnets.  Then it settles down.  Then goes wild again.
Any suggestions as to what is going on?
I would suspect the sending unit is on the way out. Take a look to see if it’s dribbling oil.
But also take a look at the wire for it. If it rubbed and shorted to ground somewhere it’ll max out the gauge every time it makes contact.
