How many of you guys run LT tires?
I appreciate the kind words. OME are tricky they have a weird part no system and constantly change their product line and part numbers. You have to go by length, stroke and what ends the shock has. I used, with a 2" lift, 60046 front and 60032 in the rear. I used OME 2934 springs in the front. I love OME used them on many Jeeps. But as always it is a personal preference, some people love them, some hate them. IMHO anything offroad that works in Australia which is the most demanding offroad environment in the world, just because of the sheer distances and heat works for me.
2 hours ago, robfg67 said:
Ok, after doing some additional research, I think my next best step is to install the control arm drop kit. I'm going to order a set from Rocky Road Outfitters because they are MJ specific.
are your arms stock length?  I think the drop kits are designed around stock length arms.
Pete, not sure how the Rusty's control arms compare in length to the stock ones.
Wow, what a can of worms.
always is.  doing nothing and simply becoming numb to the harshness is always an option too. :laugh:
Pete, wouldn't the Rusty's control arms be the same length? How else would they fit without moving the front axle?
lifting 4.5" on stock arms will ruin the alignment, especially the caster.  on cheap lifts it's usually just the lowers that are longer than stock.  on better lifts the uppers are longer too and the lowers are adjustable.  got pics of what you've got?
Hey Pete, got a picture of the lower control arm from the left side. It's from a Rusty's 4.5" lift kit and it measures 16" from bolt to bolt.
Is that enough info to tell if the the RRO drop kits will work with these non-factory control arms?
